SeminoleFSU
Voluntaryist
Love it!I'm not fond of "government knows best", and figure while we still have some freedoms left, I can keep my car's displays in the units I prefer.
I just got notified Sunday (yesterday) that there is new software available, and started it since it's WiFi tethered in my garage. Is it me, or does it seem like something is a little different with acceleration on the car? Seems like it's a little different.
For those talking about regen changes please be clear whether your experience is 5.6 -> 5.8 or 4.5 -> 5.8. I ask because I have 5.6 and want to know if I am going to experience a change. Regen I don't mind so much but please don't mess with acceleration!
I think the same concept has now been applied to acceleration too - the early acceleration is definitely "softer" although max seems the same. It's as though you have to push the pedal further to get the same level of acceleration, just like you have to lift off the accelerator more to get the same level of regen as before. Better modulated for your passengers perhaps but I kinda miss the jerkiness of the pre-5.8 regen/accel combo.
If that's the case then isn't this another "feature revert"? (well ok the air suspension was a mistake). But didn't 2 releases ago they tout "making the model S faster through software" by increasing the initial power from the pedal and making it more feel more touchy??
That sounds like a good theory...
Except that the 5 miles I lost in 22 hours were while the car was plugged in. I use scheduled charging, and the car charged Sat night. On 4.5, and likely in 5.x, top-offs only happen every other night -- so it did not charge Sunday night. So if your theory is correct, why didn't it pull from shore power to run the DC-DC converter and top off the 12V?
Also, the 12V doesn't hold all that much (I don't know the Ah rating offhand...) -- while a trickle charge makes sense, that alone should barely register against the main pack. The rest would be from the car not sleeping -- which was ~7-8 miles of range per day. 0-3 hours would equate to perhaps a loss of 1 mile of range, not 5...
Edit: My car lost 5 miles of range while parked for ~9 hours at work. That's a much faster rate than I've previously seen -- it was usually 3 under 4.5. Screens appeared to wake from sleep. I rebooted both screens and will see if that helps. If not, I'll be calling Service...
My concern about regen is that with immediate strong regen, emergency hard breaking is very quick. Does this change make it a little slower. Could this affect actual breaking distance?
Yes I have also noticed that, it seem that the Traction Control is a bit more smooth, as with 5.6 it would stop acceleration for 1-2 sec as it regained controle, but now it feels like TC set in earlier preventing it from losing grip, and thereby providing better acceleration out of corners
As noted by others above this could go both ways. Yes, aggressive regen might actually reduce breaking distance. But aggressive regen on ice can actually cause accidents too. Pick your poison.
This has been happening on pretty much every update so far. They claim that they have "improved" the way the rated range is displayed. It is the release notes somewhere.
When oh when will Tesla give owners complete revision notes .... :cursing:
Today was my first day driving my normal daily commute post 5.8 (coming from 4.5 before). My commute is abut 85% highway where I'm ranging between 60 and 80 mph.
So, it's just a data point, that could be influenced by lots of factors. But, today, on my normal daily drive, in conditions essentially the same as many other previous days, driving in a similar manner to my typical style, I set an all time low for Wh/mi for my commute. In fact, it's a sizable difference. My typical commute of late had me using about 300 Wh/mi. Today, I was at 288 Wh/mi.
So, I confirmed that the air suspension stayed at normal, even at highway speeds. I also believe strongly that they changed the regen profile. If I quickly take my foot aft the accelerator, there is noticeably less reverse lurch as before. (Again, this is my strong belief, I can't back it up with tangible proof). But I have to think that might be why I got the improved energy consumption. I try to feather best I can, but probably don't do a great job. So, having "smoother" regen might actually be better for my overall usage.
This is my theory at this point. But I was shocked that my usage dropped (and by a fair amount) given the locked suspension height setting.
I'll see if this isn't just a one-time occurrence tomorrow.
