My sense of the tweaked regen is that the onset is graduated differently. Rather than a sudden grab, it now eases into full regen. Aside from the snow and ice concern (which isn't an issue for some), the change might make cancelling cruise control less jarring. I was just getting use to putting weight on the goose pedal every time I reached to release the cruise control. That move still feels counter intuitive.... step on the accelerator slightly in order to begin slowing down).
Interesting.... I noticed that all my settings had been switched to Metric after the update and had to change them back...
Mine changed to rebel. The turbo lasers were worthless against those small fighters.
Seems like sleep still results in some variation -- here's mine: I didn't drive anywhere yesterday and the car lost 5 miles in ~22 hours after yesterday morning's upgrade to 5.8. Will see what happens while parked at work today.
The regen is very minor now, maybe they did this so we will have to buy more brake pads.
Obviously there isn't enough experience yet to draw final conclusions, but it appears that it all depends on where you are in the 12V recharge cycle when reaching your destination. At least on my car, the 12V recharge cycle takes anywhere from 2 to 3 hours to complete. It further appears that the 12V battery is not always charged when the car is being driven, so when reaching a destination, 12V charging could be done, or it could take anywhere from 0 to 3 hours before it is done.
Looking at yesterday's and today's data, it appears that sleep mode only engages at least one hour after 12V charging is complete.
So, you will lose range while the 12V is charging. Then, once the car goes to sleep, you will not lose much if any range until it needs to charge the 12V again, which will now be much later / less often than before sleep mode was available.
Is it just me, or is regen less aggressive in 5.x (I came from 4.5)? My regen is set to standard, but I don't feel the car pulling quite as much when I let my foot off the accelerator. I could just be over analyzing it.
Updated to 5.8 Saturday. This AM, handles extended, front passenger door would not open. Had to open and then close drivers door. Then passenger door responded. Returned home, placed tranny in Park, driver rear door popped open. Never had these problems before.
Personally I also prefer the "old" regen profile, I found it more useful in city stop & go traffic.
Now, with the gradual onset, I have to use my brakes more, as others have noted.
(Partial cross-post): Another thing I noted today (correct me if this already occurred in 4.5), is that when the car is locked and charging, pressing on the charge handle button interrupts the charge. I seem to remember the button doing nothing on a locked car in 4.5.
In my limited experimentation, if the car is charging but delayed charging is set to on, the charging will not resume when the handle button is released (will defer to the delay programmed hour). This may be a problem if someone plugs in to charge at a public station without turning their usual delayed charging off, and having someone fiddle with their charging cable when they are away.
