This thread discusses Range Mode for the HVAC, not the battery charging level.I would not routinely use range mode as it DOES shorten battery life at least for the Roadster. Lithium batteries degrade faster at a full charge. It will take 10's of thousands of miles to see the result as the damage is slight. If like the Roadster you will normally get better watts/mile as the power in the Roadster is cut in half. So fewer spirited launches saves on power usage.
OT: My better half likes range mode for HVAC (because of the lower noise), but I find it can't keep up with August weather.
It seems that in hot climate supercharging and rangemode is a problem, but that is perhaps not because of range mode itself, but rather the AC-limit range mode-makes.
I think you're confusing "Trip Charge" with "Range Driving Mode". I'm glad they renamed the former, in part because it assists in dispelling this confusion.I would not routinely use range mode as it DOES shorten battery life at least for the Roadster. Lithium batteries degrade faster at a full charge. It will take 10's of thousands of miles to see the result as the damage is slight. If like the Roadster you will normally get better watts/mile as the power in the Roadster is cut in half. So fewer spirited launches saves on power usage.
I go the other way. I like having knobs to turn to get improved range in a pinch. So I leave range mode off so that my "human calibration" is aligned with "normal" range.I've been in range mode since I took delivery. Havent seen a reason to change it. AC is great and summer is pretty much over in New England. Perhaps its needed for hotter places like CA or AZ?
I use range mode in the winter (except while charging) and normal mode in the summer.
I'm the opposite. I don't find Range Mode makes any difference whatsoever in the winter, so I just leave it in Normal. In the summer, I prefer the quieter operation of Range with the a/c.
Range mode in winter doesn't do much for you because you have a long commute (IIRC). Mine is 25 miles each way. Range mode really helps (as long as you can remember to charge with range mode off).
In the summer by starting with a higher than normal setting on auto (25 to 26 degrees with outside temperatures of 35 to 40) the noise doesn't get particularly loud, then I adjust it lower as the cabin cools. No loud sounds and better range than range mode.
But range mode restricts AC-output, unlrss Tesla has a mechanism that overrides this when using a SC I would say that it is a problem if chargespeed is significantly lower.Based on what?
There was one report of someone receiving a reduced charge rate at a supercharger in Arizona on a hot day, but I was also told by Tesla Service that situation occurred because of the sensitivity of Tesla's coolant pumps. In hot climates, they send out data which causes the charge current to be lowered. A number of coolant pumps have been swapped for ones with updated software, but service told me that a new firmware version (perhaps 6) will address this issue via software for the entire fleet. My pump threw an error and service is waiting for the software solution instead of replacing the pump. Engineering turned off the warning so I don't have to look at it.
There is absolutely no evidence that I can find that would implicate range mode in supercharging problems. The car will cool its systems as needed and according to its own logic, not impacted by your climate control settings.
I do. About 40 miles each way and I think that this is why Range Mode doesn't help in my circumstances. I do keep it off in the winter, but why do you recommend it? Is it because the pack heating may not be as effective?
My wish is that range mode would be automatically disabled when plugged in and then reenabled when the plug was removed (assuming it was in range mode before plugging in).
RANGE CHARGE IS ‘STICKY': Selecting a Range-mode charge is an option that will not go back to “standard” after the charge. Repeatedly charging in “Range” mode is not good for the batteries and Tesla cautions against frequent use, so user needs to remember to set this setting back to normal after a range charge.
Read more at Tesla Model S Hidden Features, Tips, Tricks Tidbits - TESLARATI.com
