The smaller can top just above 75kWh NFP and the bigger usually tops at 79-79.1.
The highest I've seen is 75,9kWh for the smaller LG 5C / M48 and 79,6kWh for the larger LG 5L / M50. Usually, as you say, 75/79.
74.5, uses the LG M48 (4800mah cell)
78.8, uses the LG M50 (5000mah cell)
To be pedantic, as you want and expect me to be... M48 ist declared as 4600Ah by Tesla, though it is not relevant here as these cells have been phased out from 2022 onwards.
Its a bit early yet but it seems like the LG pack holds up slightly better than the Panasonic.
Yes, I agree. All rated range logged data shows the average LG pack holding its capacity for longer than the equivalent Panasonic.
The cold weather performance is probably better on the Panasonic, if your question is regering to power.
Most people claim that the LG cells are allowing for more power at low cell temp, but my data shows that they are pretty much even at low temps and the Panasonic is more Powerful if the cells get warmer.
The LG need to have a higher SOC and warmer battery to deliver the full power on a M3P.
It depends on the term full power. Since the constant in Tesla's is barely ever the value power (Watts), but current (Amps) it results in a change of power with every degree of cell temperature (Voltage Sag) or every % of SoC (No load Voltage).
So you start a drive the car feels like it has constant power, but what actually happens is, that while the SOC drops you gain battery temperature which evens out the power available. Though when you leave a DC charger you will loose power with every meter as both SOC and Battery temp will drop right away.
In most cases you won’t notice a difference with a LR though.
Actually, the Panasonic NCA drops less voltage when under load than the LG NMC which results in the Long Range (980A max) being about 25kW down in power with the LG (325kW vs. 350kW). Same story with Boost + 270A (380kW vs 405kW). Both with a hot pack at 100%, so absolute max power.
I live in a very cold climate, have a M3P refresh with the 82 kWh, often drive with lower SOC and havent haf any issues with low SOC and cold battery lately.
For me it is not a big issue, but you still do notice the voltage drop at low SOC with the Panasonic, which doesn't happen with the LG. At ver low SOC I often end up with 80kW in the Panasonic Performance, were the LG still shines with +200kW. This is the LG's main party trick in my opinion...power at low SOC.
I have not been following this, so have no idea what the reason for that reduction is.
I am also convinced that this change is the introduction of thf LG 5L 79kWh Pack in the north American market.
