Once you get closer to SLC there are a few J plugs around that you could use to top off. I keep a list over on the MNL site.Thanks for the details Denarius. Park City is 200 miles from Beaver vs. 175 for Lehi. That's another 25 miles and you had 24 Rated Miles left after a full Range Charge. I could get more by slowing down but that's too close for comfort for me. Also along Route 189 there are some elevation changes -- not sure how they compare with the route to Lehi.
Just got the email that this is open, the day after you already charged! How often are you taking this route Denarius?
Just got the e-mail, also. Is this a picture from Beaver? Are they actually getting geographically correct photos these days? :wink:
Has anyone done the Beaver to Las Vegas trip without stopping in for a charge? I have an 85 but still thinking of topping off somewhere. My only concern is the holiday weekend and full rv parks.
I did the drive from Beaver to Las Vegas, but I stopped in St George to charge.
Do some real planning with EV Trip Planner.
I took a look and it seems if you do a 100% charge in Beaver, drive 55 or 60 and don't have any big headwinds, you should be OK. How's your hypermiling experience? That can be worth many miles; at least put the car in normal regen, drive smoothly, and avoid using the brakes when you can. You can probably find a place to charge mid day. Mornings and evenings may be hard. Make a list of RV Parks and phone numbers, call ahead, and don't back yourself into a corner. YMMV
I know FlasherZ would probably disapprove, but I have a custom built 14-50 "Y" cable so that I can share a 14-50 with an RV. I have used that a couple of times at full RV Parks with cooperative RV owners. I dialed my charging current back appropriately after quizzing the RV owner on what they had on. I did not pop a breaker during these "shared" charges, pulling 30-35 Amps.
The other way from Las Vegas to Beaver is a REAL challenge. Don't try that without planning an in between charge somewhere.
I have used EVTripplanner but it isn't all that accurate. It doesn't do well with roads that go up and down a lot.
I too, have found EV Trip Planner to be accurate even with mountain passes involved.
Gosh maybe its just me!
But I have also had huge weather issues on this journey too, which might be clouding my trust in EV Trip Planner. I can't remember the particular leg that was off.
Wet roads and headwinds can be a real drag, literally. The temp/wind matrix only includes wind +/- 5 mph. I've hit 25 moh headwinds and that "sucks" the battery down. When conditions are not nominal, you can lose big time. YMMV...
55mph sidewind gusts at 32 degrees....I lost more than big time!
I've done that same route in several different cars. The wind makes a 10 - 15 mpg difference. Only got 29 in the volt one trip, then 41 the next time.
