It's not programming magic, it's that they have different cooling hardware in the Model 3 which allows them to make Track Mode happen. You can't add software to S for track mode since it doesn't have the enhanced cooling like the 3.
They need to eventually update the cooling hardware in the S for faster Supercharging (250 kW) so it's pretty obvious IMO that we will eventually, and maybe very soon, see a refreshed S/X that do contain this hardware and will then have track mode.
What cooling hardware would that be? I think the S has a larger A/C compressor than the 3 does, and it certainly has the ability to use it to chill the motor coolant loop.
I think they only need one lap on the "Ring," right?
I also don't think people are expecting the Raven to be amazing, just better than non-Raven (degree to which as yet undetermined). Is the Taycan's time particularly "amazing"...ignoring that they made up their own category to be the leader of?
But the chiller that transfers heat between the coolant loop and the AC compressor is definitely different on the two cars and appears to be larger on Model 3. Hopefully i'm wrong, but i think Model S is due for some upgrades to make it compatible with 250 kW supercharging anyway and that's probably when they'd introduce a track mode and/or make it keep the motors cool automatically with a similar bit of software.
View attachment 451787 View attachment 451788
Ah, but that's the chiller assembly off of a 2012-2016 S. The Raven's is distinctly different
Nice! I could only find the one picture on the EPC site, which section is your screenshot from? Or is it from a manual/other source?
Also, chiller aside are the motor cooling methods comparable between S and 3 now? I know in the past the S/X would run the coolant through the stator prior to the inverter which meant the inverter wasn't getting the coldest coolant possible. The 3 has coolant go through the inverter and then into another plate chiller to cool the motor oil.
It's definitely possible to make an S that lasts on track, i think it's just a question of if the Raven has all of that already or if we need to wait for the next version to come out (which again, likely won't be very long from now with 250 kW supercharging)
Should we create a poll, about which trick tesla has up its sleeve?Wonder if they have a new PMSR Motor in the rear. If Tesla does the TayCan$ is hosed. Where can we place beats on his “race”?
Would be great if they put some camo tape on it, have a great lap and don’t answer any questions about it for a couple of weeks.
On the other hand - would Tesla be publically lining up a driver the week before the test? Seems risky. Unless Elon's just doing it for the extra publicity (ultimately costs to achieve track records fall under the marketing budget).Elon exaggerates but he is not an idiot. He wouldn’t have stated this if it wasn’t a go ( I think)
Well see.
Porsche likely had at least a few drivers very familiar with the Taycan and the 'ring before attempting the record run.
Either way - should be interesting, but if Tesla doesn't get at least close (meaning within 20-30 seconds), it would be rather embarrassing.
1) More efficient motor(s) in rear.
2) Software: Can it get much better performance relying primarily using the front efficient motor and only using the rear motor less frequently or under lower power?
3) Raven has improved cooling of rear motor
4) Specially modified car with extra cooling coils.
5) Other, or more than one of the above. Leave comment
I'm still not sure an S can beat the Taycan at it's specialty, but maybe that's not the intent? all Musk teased is that it will be at the 'ring next week. He didn't say why. Sport Cups aside, what if the intent is to demonstrate FSD? He could show 1) that an untrained Tesla can lap the 'ring on it's own (albeit not very fast). Maybe more importantly 2) how the same car can teach itself the track over multiple days, each day gaining familiarity and confidence just like a real driver., lapping faster and faster. To the point it can totally blow away any previous record for autonomous cars on the 'ring, even those that used lidar / high def maps and thousands of hours of tuning. That might be worth a lot more for the brand than competing against the Taycan.
