Jason71
I mean range isn't the only reason to get an LR there is also the extra motor of course. which gives youI do it either way, as mentioned in my post on normal nights I drop 90% to 80% at start of Off Peak, and then change Limit back up to 90% an hour before departure (and resume charging).
For 100% charge I want to charge "just before departure" so do the same "last 10% an hour before departure" for that reason, but my guess (but it is only that) is that will heat the battery somewhat, and reduce the time I spend on "low regen" - which might be a combination of 100% charge and cold battery. Regen seems to take "ages" to become available on a 100% charge in Winter, compared to Summer, so (subjectively) I reckon cold battery comes into play too.
Also possible that quite a lot of variability has crept in between an old 2016 MS like I had, and a new, improved-design, Model-3
All may become moot with the new "Precondition for departure" dashboard option ..
I'll assume 50% recovered on sale and owning the car for 4 years. 4 years * 5 hours p.a. = 20 hours saved.
£4,500 / 20 = £225 per hour. Looks better for people that would save more hours, of course.
Might be worse than 5 hours p.a. if you start finding all stalls occupied, or having to pair more often. I've upgraded to Raven (old car had got to high mileage) and the extra range fixes a couple of journeys which I used to take the ICE for. That extra range will change my Supercharging from 2 days a month, to 2 days a year, and I do wonder if will turn out to be a benefit if rollout of Model-3 numbers greater exceeds Supercharger capacity rollout
AWD for Bad Weather
AWD for less chance of breaking down ( i.e. a backup motor)
The extra performance.
I do a lot of driving in rural hilly areas with very limited access to rapid chargers and lots of bad weather so for me it was worth stumping up the extra. I can't quantify any of them in hours per year though.
