I disagree with the comments here about heaters etc. using up significant range on long Winter trips. There is the possibility that my Model-S experience, through 3 winters, may not translate to Model-3.
For a SHORT journey then all bets are off for consumption. That is not the same as, nor relevant to, consumption assumptions for max-range / long journeys
For a long journey in Winter, and having pre-conditioned the car before I set off, I have about 10% reduction on long Winter trips (e.g. driving SOC 100% down to 20% or lower) compared to Summer. Winter, for me down South, is temperatures averaging around 5C
Even with preconditioning (on shore-power) the car will still have had reduced regen, I have not found any way to precondition such that the battery is actually at driving-temperature, so I still have some set-off-penalty, just "reduced" if I pre-condition on shore power
My winter journeys are dual carriageway at 70 MPH. In practice my average speed shows lower than that due to traffic / roadworks. The energy consumption for heater is not a significant consumption at 70 MPH (it is a significant consumption at 20-30 MPH, but doing max-range at that speed will take forever
... so the two are usually mutually exclusive). I don't wear a thick coat and a bubble hat when I'm driving
but I may knock the heater down a degree or two - but typically not below 21C
Ambient temperatures 0C, or lower, will have more impact. I have very few journeys that were that cold, so no useful data to share.
Wet is a different thing altogether. Summer or Winter then heavy rain makes a huge difference (20% easily). Slowing down doesn't help much, still the same amount of water to push out of the way mile-after-mile. Same is true of ICE of course, just less noticeable with a Big Fuel Tank.
I’ve just completed a road trip between Glasgow, Derby and Edinburgh.
I was very disappointed in the range of my model 3 when driving at around 60 mph.
I suggest trying your journey in
A Better Route Planner - even just using "ideal" summer conditions for your model. Would be interesting to compare that with your actual; you could also set Winter Temperature, Wet and Wind to get a prediction figure matching your actual conditions. Your 150 mile journey is a reasonable length. If you were not able to pre-condition (on shore-power) before setting off, and the battery was cold (parked outside rather than in garage, and stopped for long enough to get down to ambient temperatures, and ambient was 0C-ish, or had been down that low (e.g. overnight, even if ambient increases during the day the battery won't be warming as quickly as the air does), then the set-off energy penalty will be huge
If you have to stop on your journey, for an hour or more, you will have the full "cold set off energy penalty" each time, as the battery will get cold-soaked again
Plugging into 13Amp, before departure, and charging the battery for an hour (and the cabin for 15 minutes or so) should help a fair bit.
The charge showed 250 mile range on setting off
I expect you know this, but if you select Energy : Trip (after putting destination into SatNav or, if at Supercharger and still showing that location as "current" then press "Continue journey" to get next leg), that will show predicted energy on arrival at destination. That is not going to take into account weather on the next leg, so you need to allow for that ... apologies if you know about that, if not it might be worth a try, so that you set off from Supercharger with a prediction of arrival SOC that you want to achieve, and then during the journey you can see if the predicted arrival energy is getting dangerously low and slow down, or add a charging stop.
I would also recommend checking ABRP for long journeys (setting anticipated weather etc.) and making a note of the departure SOC %ages for the various stops. Of course if you have regular trips you will become familiar with what you need in practice.
That sort of journey is definitely the scenario where larger battery helps:
More miles until need to charge (obviously
Less likelihood of needing to charge above 80% - which is dramatically slower than 10% -70%
Faster charging (generally speaking larger batteries charge faster, either just more-cells-in-parallel or in some cases larger battery model charges at high voltage and so on)
Possibility of "choice" of chargers, that greater range brings, so on occasions ability to get to a further, more suitable, charger
I also kept our small ICE car (hardly used) until I can be sure I can go fully electric so have that option too
Snap. I've now moved to Raven MS which solves all the trips that I used to take Backup-ICE on, so I can now ditch that for a backup-EV instead
