Current pack heating on models not including the P90D uses shore power when plugged in, but only works with range mode off, or when the pack has to be heated to charge it. So, for example, what many of us in cold climates do is we try to time overnight charges to end close to the time of our morning departures, so that the pack is still warm from having been charged. If we remember to turn range mode off, we can also heat the pack by pre-heating the car. In both of the above scenarios, though, I believe when it is cold the pack will not heat beyond the point where it will be regen limited to 30kW.
Having the Ludicrous Mode may not help you much with respect to actually driving ludicrously from the gun club to home. But if it works to heat the pack, you may be able to use it to heat the pack such that you leave home with almost no or even no regen limit when it is very cold. Assuming there is any pack degradation taking place when the pack is fully heated to the point where Ludicrous Mode is fully available, you would want to consider shutting off the heating before it reached that point if your only goal was to have no regen limit. I could be wrong, but I would have to think that if you only heated the pack to the point of no regen limit, you couldn't be causing any pack degradation due to the heat, since the pack would still be quite cold.
I guess what I'm saying is that you could use the ability to heat the pack as a separate feature not available on the older cars. It's a feature we've been asking for, but don't have yet.
