Yes, the increased chemical reactivity that allows for more power also accelerates the rate of degradation. Thus if you are going to use the mode, it is best to limit the amount of time it is in the ready state.With higher temp, does it not come with higher degradation?
I doubt that the increase will be significant, or measurable, I suspect that in a couple years the difference in degradation between frequent and infrequent ludicrous launchers will be below the noise threshold. As seems to be the case today with those who frequently charge to 100%.For sure it does.
So basically now the P90DL has a "launch mode"? lol
lol. Just unlike in a Porsche, you have to wait a few minutes for it to engage, by which time your opponent is a blur in the distance
I am just on the fence with this and here in CT where we have very cold winter environment for 4+ months, what will the lag time be, after invoking MBP when we have 25 degrees F?
As it is now in the Northeast,
ArtInCT, it really does sound like they had to really pull out the stops at all cost to hit the 2.9 figure. Even if just to say it's possible
I'd love to know if without this pre-heat Ludicrous the performance is the same as Insane. If so it seems a waste of time unless you only intend to use it on a sanctioned drag strip.
One thing is for certain, pack heating cripples my range. I do an 8 mile each way commute, and at 32f air temps the "warm up tax" is significant enough to halve my average Wh/mi figure overall.
I'm also intrigued what happens with regen with this on?
Overall though i'm truly struggling to see an upside here.
launch pre-heat L-mode > I-mode. 30-60 is definitely better, and 60+ is also better. I'm taking sorka, who has talked a lot about P85D performance, for a ride this week. So hopefully he will share his opinion afterwards. I think he will most likely notice even the small differences since he has owned a P85D for a while.
I haven't paid a lot of attention regarding regen with the option on. I am doing another reaction video at 2pm so I can see then.
Thanks for taking the time to answer, and apologies if it comes across as me putting down your car, it's more a frustration with recent directions at Tesla as a whole!
I look forward to hearing Sorka's feedback. IF the L mode = requires pre-heat (with subsequent range issues) then it could be a deal breaker for some, and one more thing Tesla probably should put as a disclaimer on the order page.
Either way it's still no doubt a fantastic car, and I hope you enjoy it!
You have kind of just said what I was thinking about ever since reading about the MAX BATTERY POWER setting. It seems rather fiddly to me.
I mean really, if I am driving along with the MAP high and the Energy Curve low on the 17" display and then want to engage MAX BATTERY POWER....
Well, how many distracting display touches will it take to do that?
I suspect you cannot promote the MAX BATTERY POWER setting to the thumbwheels?
As it is now in the Northeast, most Model S suffer from NO REGEN when traction packs are cold soaked in below freezing temps (until the pack warms up).
Ahhh... sheet... Sadly, I just may drop the UNDERLINE from my P90D config...
Didn't think you were putting it down.
Someone on TMC (owner shall remain nameless to avoid requests to borrow) is going to let me borrow a VBOX. So I will be able to show the performance of sport vs L-mode vs L-mode-heated.
Sorka asked me to use PowerTools to show the KW used, but I've had some issues logging in while other apps work. So I need to troubleshoot that and then I can post some information on the KW at max acceleration.
Andy I'd read it as "how long will pre-heat take in cold weather?" not "lack of regen is a decision factor"
Driving around for me it takes 20+ minutes for the regen limit to fully disappear, let alone warm the pack up to the higher level the max mode uses.
OK Thinking about this a few more questions spring to mind.
So should (/can) this be left permanently on? (Did the DS give you any guidance, or notes in the manual)
Does it reset itself every time you start the car?
Can you tell from the dash when it's finished "preparing"?
Does the performance build up gradually? (Or is there a binary step when it's finished?)
Another Scenario... On the other hand, in the garage, when on shore power that MAX BATTERY POWER could be of benefit IF all the power were coming from the shore power and NOT from the battery pack to preheat the traction battery. Do you know if preheating uses 100% shore power or does it utilize traction pack battery power?
