Thanks Larry, that makes much more sense. I couldn't see why we'd need to fully recharge in an hour at home. Makes sense that the home ones are "standard" while the superchargers give you the "quick boost"
Volume is low, but it sounds like he says the 90kw charger can get you 100 miles in 22 minutes (so an hour and 6 minutes from empty to 100% full in 300 mile pack)
Did they say if they would all be red or color match the Signature colors to start? Thanks.
I asked that question at a previous event, and you can get your HPC to match the color of the car.
No you're right. Whoever wrote the above email is mistaken. Hardwired means you don't have a plug (NEMA 14-50 or otherwise) in between. Though if you don't have 100 amps available, I'm sure the HPWC can be set for a lower amperage.Why does it say NEMA 14-50 then talk about 100A and being hardwired? I always thought NEMA 14-50 was a plug type and referred to 50A but guess that's not correct.
Can anyone suggest the reason for the "at least 3 feet above ground" requirement? I had been hoping to have it somewhat lower.
