spatterso911
P100DL - Raven
If the wall stays dumb then the price can stay low.
All the better for installing multiple locations.
Good point!
ultimately the Tesla HPWC (which I'll modify with an appropriate plug if it's only sold in hardwire form) will then plug into a receptacle integrated into the PVC post. This will make everything easy to disassemble when the car is not being charged. It will also make it all easily portable.
I start working on this soon and will post some photos when it's fully assembled.
Remember that the HPWC comes with a 25 foot cord. Pretty long. Maybe you dont have to go all the way to the street with it, or maybe they would make one with a longer cord appropriate for your use?
Is anyone aware of a solution to make a single HPC work with both the Roadster and Model S? Alternatively, is it safe and/or possible to connect both the Roadster HPC and Model S HPWC to a single 100-amp circuit, given that I will use only one at a time (or if both at once, limit the total draw to 80 amps)? I ask because I have a Roadster which I plan to keep, an original installed HPC on a 100-amp breaker, and a Model S on the way.
Delivery Update
Heard today that the HPWC is currently awaiting UL approval. That is expected sometime soon and then production can start, followed by shipping of course. Tesla provided this helpful document for installing a temporary outlet.
This is interesting. Is there a reason to install a 6-50 outlet as opposed to the 14-50 that keeps getting recommended around here? Does it have to do with the upgrade path to the HPC?
I think that it has to do with the number of wires run to the HPWC. The HPWC and the 6-50 only use the 240V wires and ground for a total of 3 wires. The 14-50 has a fourth neutral wire, so that you can connect 120V devices as well. You either need to run a fourth wire (neutral) for the 14-50 or use a 6-50. Not connecting the neutral on the 14-50 could cause confusion or possibly danger later. A solution that will work, is not code compliant, and I am not recommending, is to connect ground to neutral at the 14-50. In new installations, neutral and ground are only connected at the service entrance panel.
The 14-50 is the more common connector and is the 50A standard in RV parks and marinas. The most common applications for the 6-50 are large room air conditioners and arc welders. NEMA connector - Wikipedia, the free encyclopedia
Thanks, Cottonwood. This makes sense. Just so I understand, if I go with their recommendation the "free" extra connector I get will be different, and cause me some potential issues at public charging stations? I think that's what your saying, although you don't explicitly mention the choice of free connectors.
