What is the recommended tire rotation schedule for the 21" Contis with the goal to replace all four tires at same time
do you feel it is camber alone that is driving the whole issue?
If it is, why would there be such a large disparity between drivers?
When you swap a tire do they remove it from the rim and turn it around? Also, does tire rotation always mean left front to left back for example (and left back goes to left front) or do you ever sway left front for right front or right rear? If Tesla won't do this for free at the service centers I wonder if the frequent rotations eats away at the savings from the tires lasting longer.
My Model S has a bit over 8,000 miles now, the tires have never been rotated and the tread depth looks good and even to my eye all around. I suppose I should pick up a tread depth gauge to be sure.
I have the OEM Goodyear Eagle RS-A2 19" which are not very good tires, noisy and harsh. I have 3400+ miles on and the treads of the outer edge is gone for all 4 tires and I'm not sure why. I had the tires lower to 42 lbs for a couple of months to get a softer ride (supported by my local service manager). Did I under-inflate? Need inputs.. Very disappointed. I plan to get rotated at 6K miles but not sure if it changes anything.
The 21's (Conti's and Pilots) are directional tires, so you cannot rotate across sides, or you would be mounting a tire to rotate against its tread design. You can, as Jerry points out above, have the tire removed from the wheel and remounted (outside in) on the same wheel, and then be able to swap sides for more even wear.
It's not a bad idea to have something in your garage to be able to check yourself now and then. That way you don't end up driving on balding tires for safety reasons. I bought this and it measures in inches and mm
Amazon.com: Central Tools 3S401 Digital Tire Tread Depth Gage: Automotive
