He clearly is running a lot of regen. I also see the traction/yaw control constantly triggering. I wonder if it's good enough to help or hinder on a track like this? I bet it can be disabled with a simple fuse pull.
Hmm, would adding a beefier pump with more flow help? Seems like with the size of the radiator and A/C there should be enough heat transfer to get rid of it all. Maybe it's not even kicking in the A/C?
Yeah, getting the inverter, rotor and stator temps would help a lot. While we're at it, add in the pump RPM's, A/C compressor target, valve positions, etc. Seeing these would help us to devise a system to keep them cooler for track use. Tesla probably doesn't care about such things, but maybe there's an Engineer or two that would be interested enough to help off-hours. I bet Elon would be ok with this, even though I don't see him officially tasking engineering with such a project.
I devised a hack to the LEAF's HVAC controller to allow direct control of the system's cabin fluid heater. This was before the addition of the heat pump. Their HVAC team had (badly) engineered the system to turn on the heater anytime the glycol loop was below a certain temp, which led to a LOT of wasted energy consumption. When you only have about 21kWh usable, that ~5kW heater load is a serious issue. Luckily Nissan listened to us when we asked for a heat-pump in 2011. They added it in 2013, which is pretty awesome. Now it only Tesla would do it...
