So I don't know where you get the EPA number of 305 from
From the EPA website:
Compare Side-by-Side
So you can see that according to the EPA it is:
70D: 330wh/mi
85D: 340wh/mi
60: 350wh/mi
P85D: 360wh/mi
85: 380wh/mi
What doesn't make sense to me is how the P85D is somehow *more* efficient than the 85, yet it gets lower mileage???
Clearly their numbers are either A: accounting for some kind of loss in charging. B: totally made up??? C: Someone made a typo on the P85D (seriously it is the only one that doesn't make any lick of sense)
Anyway, throwing out the P85D because something just isn't adding up there, you can see that the efficiency difference based on EPA numbers is 8% for the 85->60 (380 -> 350) (obviously weight savings gives you the 8%) and from the 85D -> 70D (340 -> 330) is 3% efficiency gain. So based just on the numbers posted by the EPA, and assuming that whatever charging inefficiency they are hitting you on here is equal across all cars (which might not actually be the case I admit that) I am actually on the side that says it isn't being contributed to some kind of weight savings.
That doesn't necessarily mean they aren't better cells. For all we know, they have either A: Been using better cells for a while now across all cars, or B: the better cells didn't improve the weight and in fact made the cells heavier, they just fit more power in a smaller package (which is somewhat important all by itself, more power but increased weight, same volume, and if they are *cheaper*??? why wouldn't you use them?). In any case 3% for a 10kWh drop vs 8% for a 25kWh drop any minor non-matchup here is likely attributed to the more efficient motors than anything.
- - - Updated - - -
If 8% is equally dropping per pound then going from 60 to 85 cost them 1% per 3.125kWh. Similarly in going from the 70D to 85D it cost them 1% per 5kWh.
Is the Dual Motors really that much more efficient that the added weight doesn't make as large of an impact to efficiency?
Let's look at a different comparison to find out. 85 vs 85D. This is 380 -> 340 which is an efficiency gain of 11%!!! With a smaller motor in the back to make up for a small motor in front, I would bet that there isn't too much weight difference between the two. Even if there was, that is still 11% being gained *straight* from adding the dual motor. I am willing to believe that 1% efficiency loss per 5kWh number up above as the motors are making the car more efficient in a big way, in-spite of the weight difference.
