J
One other thing to keep in mind, just because Tesla says that a pack is 85, 60, 70 kwh or whatever, doesn't mean that it is exactly that number. They(like everyone else) round up, and rate them in different ways. A good example is the Roadster pack, depending on what timeframe you look at, Tesla rated the same pack at both 56, and 53kwh. That is quite a difference.
Trying to get an idea of what cells Tesla is using from pack weight and kwh capacity, is pretty much impossible(unless you know some other details).
That's a regular production pack. They did open it differently, but that is not relevant. Same pack cover. The two dummy modules are made of metal, but who knows what metal Tesla used. The 60kwh packs do use fewer cells per module. This isn't any secret.What is also interesting about that pic is the way the pack has been opened.
If you look at wk057's thread:
Pics/Info: Inside the battery pack
You can clearly see that the cover is a simple pressed piece of sheet metal, with the ribs formed as part of the pressing.
The picture we see here has hinged metal bars forming the strengthening ribs of the pack cover.
The layout of the dummy cells is also bugging me. If we think how the pack manufacture would be automated, i.e. using a continuous process a bit like say a bottling plant, why are the dummy cells not missing in a contiguous block, or at least at the end of each strip of cells?
Then there is the issue of balancing individual cells, such a configuration would seem really hard for each strip to balance, or am I missing something?
Overall, it really does look like an early engineering test bed. Only when some third party like WK057 takes apart a production 60 pack and documents it in such detail as the 85 (big thanks to him btw, I found the thread fascinating,) will we truly know.
I have a niggling feeling it would have simplified production and inventory issues to have identical modules and to have simply absorbed the additional cell count cost on the small percentage of modules destined for 60 packs, software limit them to give a decent model differentiation and in the majority of cases recoup that back via Supercharging fees anyway.
