Panu
I don't know why but some people insist on having a RWD
Reasons:
1. Lower price
2. Only one motor means less maintenance
3. Larger frunk
Using the same formula with the 85 kWh pack and you get 294 miles. There obviously have been some efficiency gains in the 70D, since the 85D comes no where near that mileage number.
The German specifications table is interesting:
Though there's none of that nonsense about anticipated gas savings, there are two different figures given for the power of each vehicle: their horsepower and their "nominal motor capacity." So the 70D is 334 horsepower (I think our units are different), but has a nominal capacity of 522 horsepower in the motors. Then you have 367 horsepower and 385 potential horsepower for the S85, 428 and 522 for the 85D — and then the P85D confuses the lot by only showing its "nominal motor capacity" and not its listed horsepower.
It's odd how all of that works. Either way, I'm very happy with the 428/522 PS I have coming to me next month.
I suspect you're right, though the cynical part of me thinks that they can just use up those components in driveline replacements over the next few years.
it may, in fact, be closer to the 416 hp that Tesla originally quoted for the P85.
There is a real number for P85D: 413 hp. See dyno test hereHaven't we known for a while that some of the configurations were limited by the amount of power the battery could provide? I recall seeing a table (back in the 60/85/P85 days) that suggested the 60 was battery limited (same inverter/motor as the 85), the 85 was inverter limited (same motor as the P85, different inverter), and the P85 was battery limited.
There was an update to the stats last year that showed the S60 and the S85 making the same nominal HP (it went from 300 v. 362 to 370ish for both). Despite that, and despite the lower weight of the S60, the S60 was not listed as having a lower 60 time (and I don't think anyone has ever said that an S60 is faster than an S85).
That all suggests that Tesla went from reporting the "actual" expected HP based on the battery/motor combo to just reporting the theoretical max HP of the motor. Which, of course, is next to useless if the battery doesn't have enough juice to actually hit that theoretical max.
The numbers above support that theory, in my mind--that's why you see larger "nominal motor capacity" numbers, and lower hp numbers.
The thing that's irritating is that we've never seen a "real" number for the P85D. If the P85 really was battery limited, it's quite possible that the "real" number for the P85D is a LOT lower than "700" or "691" hp; it may, in fact, be closer to the 416 hp that Tesla originally quoted for the P85.
http://www.dragtimes.com/blog/tesla-model-s-p85d-shocks-the-dyno-with-864-ft-lbs-of-torque
So you are probably right, it is battery limited.
For P85 there are multiple dyno stats available, a quick google search gives something like 360 to 460 hp from different tests. Probably varying with SOC, dyno calibration and other factors
I haven't cited it before, but what is the correct power then?Stop citing that dyno test. It came from a dyno not capable of handling an AWD car with independent motors. As such it only captured the rear wheels.
- - - Updated - - -
This is kind of OT, but where did you get that picture from and is there more where it came from? I'm most interested in the actual (non-blank) cell count of the 60kWh modules. This has been a huge mystery for some time, since we have known that the 60kWh has 14 modules, but the math doesn't match up with the 16 modules of the 85kWh.
There were 3 possibilities: either less cells in the modules, lower capacity cells, or both. This picture shows there are less non-blank cells per module (although it doesn't necessarily eliminate the possibility of lower capacity cells, without knowing the cell count).
the cells for the model 3 will be larger then 18650 cells and I assume once the giga factory is up and running the model S will use the same cells
If that were the case, the 0 to 60 times would be closer. The P85D clearly has more horses going to the ground.
I know that the electric motors have different characteristics than the ICE vehicles (favouring a lower 0-60 timein the EVs), but you should take a look at this website anyway. If you set a dual clutch configuration and enter in the data from the P85D & P85, the 0-60 numbers are not too far off.
0-60 mph Calculator for Cars
Is there a source for this information?
But honestly Tesla, stop with the fuzzy math, just give us the price... Gas savings is not going to help me when I'm paying for the car.
Not necessarily; not if the big issue with the P85 is traction limits, particularly at launch. And that's where the P85D really distinguishes itself.
Not to be all tin-foil hattish about this, but why does the German site break out actual v. theoretical power for every configuration *other than* the P85D? I honestly don't know the answer to that question.
the 0-60 calculator is based on evidence with gas cars. As we all know gas cars are outrageously inefficient compared to electrics.If that were the case, the 0 to 60 times would be closer. The P85D clearly has more horses going to the ground.
I'm sure Elon is aware of the quote above as well. :wink:
