George mention different front and back on the X.I thought someone else here mentioned that as well. Is that what they're doing on the X?
The next gen roadster doesn't need a transmission just 4 wheel drive with different gearing on each axel, rear axel is a low gear for high torque off the line 0-60 and front axel is geared towards a tall gear for 60mph to 150+
I think the motor RPM limits may be due to mechanical things like bearings etc., so I'm not sure how different you could make the gear ratios without overspeeding your low gear drivetrain at top speed...
I don't want a transmission, period. If possible, I'd like to keep power steering out of things too, but I accept that I'm probably just weird on that front.....
Just to clarify - single-speed EVs definitely do put down max rated power - the only issue is that you have to be moving fast enough to do so - the real issue is that you only have a very narrow window of max rated torque and power along with a maximum RPM at which you can maintain max rated power. Max rated power is often limited by what the battery and other components are capable of delivering as well as how well the motor is cooled.Single speed gearbox is simple but it also means vehicle is almost never capable of outputting its max rated power.
ICE car accelerating to its max speed goes over max power six times (with six-speed gearbox), Roadster and Model S only once.
They could always have a "performance" or track edition for those who plan to race.
I am betting that they make a standard Model R that is like $150,000, which is luxurious inside and has a 0-60 time of 3.3 seconds and they have a Model R / Racing / Ring Edition that sells for $250,000 and is AWD with 0-60 time of 2.5 seconds and a top speed necessary to make it the fastest lap at Nurburgring. This hyper-performance version would be all carbon fiber, have special batteries (probably fewer of them to save weight) et cetera. Basically they do everything necessary to shave the weight and increase the performance until they have a Ring beater.
The great thing about the Nurburgring is that it's only a 7 minute / 12.8 mile race and it carries tremendous credibility with car nuts.
Going 250 miles is stupid because you can only do it on an airstrip or special racetrack and besides there is no chance the Model R will ever break 200 mph. So if you want to be "the fastest car in the world" you better aim for a preposition of "around the Ring" rather than "in a straight line."
Hope that makes sense. I'm sure a picture would help visualize this...
