jstepy
I called and SCE can recalculate past years usage at the new rates to compare what would work best for you.... EXCEPT if you have met metering and solar. So it's kind of a crap shoot to figure out what would be best.
Problem 3: I honestly cannot figure out how SCE allocates Tier 1 allowances for plans like TOU-D-T and the baseline that the Tier 1 allowance is calculated from changes over the course of a year... so we had to model it assuming that Tier 2 would never be encountered. I also haven't yet gotten a good answer as to what the -$0.10/kWh Baseline Allocation Credit on the TOU-D-A plan actually is. During my first call with SCE yesterday, I was told that they'd take the total net kWh usage for a billing period, multiply by -$0.10, and then apply that as a credit to the bill. This doesn't make sense to me... also, does it mean that SCE is going to charge us during the 3 months or so per year where we produce more power than we consume? I'm waiting for further confirmation from them and, in the meantime, we had to exclude it from our model.
Welcome! I can help with Problem 3, as I figured all this out when I was doing my initial cost projections for solar. SCE allocates Tier 1 allowances as follows:
They take your total usage in each TOU period for the whole month, and determine what percentage of your total monthly use is in each period. For example, if you had 200 kWh Peak, 300 kWh Off-Peak and 500 kWh Super-Off Peak, they'll break that into 20% Peak, 30% Off-Peak, and 50% Super-Off Peak. Then then take your Tier 1 allowance, and divide it into a tier 1 allowance for each TOU period based on those percentages. Each TOU period thus enters Tier 2 at a different time. They can't do this calculation until the end of the month, but they do list the calculation they did in your bill as supporting text on the right side of the bill. If your billing period includes the switch from summer to winter or vice-versa, they'll split the allowance between winter and summer based on number of days in each and then do the calculation as normal for each TOU period in each season separately.
Does that make sense?
I'm disappointed that the Green Dot data doesn't include -kWh periods. I've been having problems with my TED monitoring system recently, and I had figured I could use the Green Dot data in place of it, but I guess not. I should get the TED system back working.
Yes, that makes sense and I now understand what I was doing wrong while trying to figure it out. The question now is whether or not we should spend the time incorporating that into the model to improve the accuracy of the TOU-D-T projection...
Our TED monitoring system quit working correctly a while ago.
I am on the same plan as you...the letter says I will be automatically switched in February.
- - - Updated - - -
View attachment 67936View attachment 67936
Fengshui,
When you mention the basic D rate, do you mean TOU-D-T otherwise described by SCE as Off Peak Savings plan?
The shift in peak rates is problematic but the somewhat high rates across the board largely make up for it for us (we have really significant production that starts as early as 8:00am year round and doesn't wind down until 4:00-5:00pm). Interestingly, based on the 2014 data, our net on peak tracked charge under TOU-D-A would come out to -$0.289 (so, pretty much a break even), the off peak would be -$740.584, and super off peak would come to $429.66 (which is where the -$397 came from).Great. TOU-D-B is great for people who use lots of power without generation, certainly. For Solar with an EV, I think TOU-D-A is the only decent choice. We get screwed by the on-peak shift to later in the day, but TOU-D-B is worse due to the low payouts for Net Excess during the height of production. -A still provides a worst-case 2.5:1 credit ratio for daytime generation used for night-time charging. -B gives barely 30% more during winter months. I also want to discourage any attempt by SCE to claim that their customers don't mind a large $19/month Basic Charge
I've heard that explanation as well... Supposedly a NEM person from SCE should be contacting me this week to confirm. If it does work that way, then at least in my case, TOU-D-A could work out even better for me than TOU-D-TEV. That's an easy thing to add to the model once I have confirmation.Let me add a guess about the baseline credit. I believe, but have not verified that you multiply it times your monthly baseline kWh. In my case the baseline is 360kwh in winter so it is $36.
Nope. I was referring to the basic Residential, D(omestic) rate, with no TOU and 4 tiers. Since there's no TOU, you get full credit for each kWh you generate. You may not eliminate your bill that way, but with Tier 1 at $0.15/kWh, it's not all that bad. TOU-D is a bad rate for EV owners, because it doesn't take much overnight charging to put you in Tier 2 there, which runs $0.25/kWh. I run almost 500 kWh per month in the current Super-Off-Peak Period (midnight-6am), and I expect more EV owners are similar. You want the -A rate for that juicy $0.11/kWh overnight rate with an EV.
Interesting! So what I'm hearing is that the Baseline Allocation Credit is determined on your net kWh usage, not your monthly credit/debit. Here's an example:- The Baseline Allocation Credit that's part of TOU-D-A can be both a good thing and a bad thing--net consumers will be happy, people who are consistently net producers won't be so thrilled. The TOU/NEM rep that I spoke with stated that net consumption up to your baseline amount (in kWh) per billing cycle would be credited to your tracked charges at $0.10/kWh. The same, however, applies to months in which you're a net producer... each kWh of net production will result in a $0.10/kWh charge being applied to your tracked charges up to your monthly baseline. In this case, net production beyond your monthly baseline wouldn't result in additional charges.
It does appear to be determined via net usage; however, the specific situation you described falls into the 'does the credit function in a <$0 capacity' issue that I brought up a little later in my post. If it does, then, yes, the total tracked charge for that month would be -$56.95. If it doesn't, then you'd just get the straight -$10.45 added to the tracked charges. I'm going to inquire further to clarify this detail of the Baseline Allocation Credit.Interesting! So what I'm hearing is that the Baseline Allocation Credit is determined on your net kWh usage, not your monthly credit/debit. Here's an example:
If during a summer month where you had a baseline allocation of 465kWh, your net power usage was 669kWh, and your monthly charge was -$10.45 (due to credits from Peak Production outweighting your debits from Super Off-Peak Consumption), you would still receive a $46.50 credit to your tracked charges.
Is that correct?
I just received another call from SCE's TOU/NEM folks and they have confirmed that, yes, the Baseline Allocation Credit should work in a <$0 capacity. So, yes, in your example you would end up with a tracked charge of -$56.95 for the billing period.Interesting! So what I'm hearing is that the Baseline Allocation Credit is determined on your net kWh usage, not your monthly credit/debit. Here's an example:
Is that correct?
Well, it depends... Are you a net metered customer (solar)? If so, then you'll receive the $17 credit assuming that your net power usage was equal to or greater than 170kWh for the given billing period. If your net usage was less than 170kWh but greater than 0kWh, then you'd receive a credit equal to $0.10/kWh above 0kWh up to 170kWh. If your net usage for a billing period happens to be negative (you produced more power than you used), then you would receive a charge instead of a credit. Make sense?@ Petra - Could you dumb down the whole baseline credit explanation? I am sorry but I am still a little confused... the way SCE explained it to me was I'd basically get a credit every month. Living in Huntington Beach I was told my baseline is 170 kWh... so I would expect a credit of 17 bucks every bill. Was SCE totally wrong?
Anything new on this issue? I just got a new letter from SCE.
Baseline allowance for distribution to TOU periods is the minimum of the standard allocation as set forth in Preliminary Statement, Part H, or total metered kWh for the billing cycle
