BrokerDon
Hmmm...
We switched to SCE's TOU-B-D rate https://www.sce.com/wps/portal/home/residential/rates/Time-Of-Use-Residential-Rate-Plans when we got our 2015 Tesla P85D with dual 40A onboard chargers 13 months ago. Our SCE Time Of Use pricing is:
We charge our Tesla at 60A / 240V starting at 10:00 PM nightly using our 80A Tesla High Power Wall Charger. This typically completes the recharge of our Tesla's 85kWh battery to 90% full in under 5 hours... All at SCE's Super Off Peak 13¢ to 14¢ / kWh rate and well before the 8:00 AM start of the slightly higher 16¢ to 17¢ / kWh Off Peak Rate.
Obviously if you're unable to charge during the lowest Super Off-Peak rates, you should consider getting a 240V charger like an eMotorWerks JuiceBox which would significantly reduce your charge time. However since the kWh rate only goes up 3¢ / kWh from Super Off-Peak to Off-Peak, your payback might not justify the cost of a 240V charger including installation.
Also, consider SCE's Summer Discount Plan https://www.sce.com/wps/portal/home/residential/rebates-savings/summer-discount-plan if you have central AC since this can significantly lower your summer electric bill. Our monthly SCE bill for 700kWh drops $125 to $150 a month each summer for SCE's ability to turn our AC units off during Demand Response events... Typically a couple of hours between 2:00 pM and 8:00 PM on 6 to 10 days a year.
If SCE's Summer Discount Plan is too onerous, you could also earn credit$ from other Demand Response Providers simply by allowing them to remotely cycle your EV charging (and other devices connected via their Smart Switches & Thermostats) OFF during SCE Demand Response events:
If you do decide to buy products or enroll in eMotorWerks or OhmConnect rewards programs, please let them know I referred you since you'll probably get their lower referral New Customer promotions... and both companies have been very helpful lowering my SCE bill through their hardware & business services. HIGHLY RECOMMENDED
Good luck!
Don
- eMotorWerks: Rewards
- OhmConnect: http://ohm.co/db12c2
Good luck!
Don
