Apologies if this has been asked an answered...
HPWC is now installed. I have the 85kw with twin chargers.
I'm still only getting 40 amps. I tried manually setting the amps to 80... plugged in the HPWC, reverted to 40 amps.
The HPWC is connected to a 100A breaker in a subpanel, which is fed by a 100A breaker at my main panel. We set the dip switches for a 100A feed.
I've called the LA service center, and they're pulling the logs. While they're doing that... figured I'd ask you brilliant folks and see if there was something obvious I was missing.
has your charge been depleted to the point where the twin chargers would kick in, we don't use very much during the day, just a run into toun and run around so maybe twenty or thirty miles of charge. I would expect when only topping up my charger will only supply a small amout to save the battery , I have seen the same as you, we will be going to Tampa next week which will really test the battery to about 2200 miles worht and then I will know when I put it on charge.
