We got back last night in Merced at midnight. Drove straight from the Grand Canyon. The Fresno supercharger can't come fast enough. We would have saved an hour. Anyways, still on vacation and still bound by my promise to my wife to stay off the forums until next week but I couldn't help myself.
Charged up to 93% while max battery mode was engaged. Turns out you can turn this on while charging and away from the car. It took an hour to get to "ready". Runs were done starting at 91%. The very last had just hit 89%.
Did multiple acceleration runs starting at different speeds using the vbox and also ran power tools for each run to see what the battery was doing.
Starting MPH | 50-80 MPH | 60-85MPH |
0 | 3.00 | 2.87 |
46 | 3.00 | 2.87 |
47 | 2.96 | 2.81 |
47 | 2.96 | 2.81 |
57 | - | 2.85 |
57 | - | 2.81 |
Some of these values are identical. They aren't typos. The values starting from 0 MPH and 46 MPH are identical to the hundredth. Same with both runs starting at 47 MPH. Crazy consistent. There doesn't seem to be any penalty for starting at 0 vs starting just before the speed range tested.
Max power seen from the streaming API (sampled 4 times per second) was 415KW at 91%. Previous best without max battery was 414KW. Not statistically interesting.
The difference in power between a non Ludicrous P85D at 90% vs 68% is 50KW or about 67 horsepower at the battery. What is this at the shaft? 60 hp? Nobody knows for sure but it's certainly a few % less than at the battery.
Given the power output from the battery is so flat, it seems hard to believe that only 425KW has been seen. The P85DL at 68% is performing like a P85D at 90%.
.....unless it turns out that the P85DL can *ALSO* pump at 425KW even at 68%.
Could it be that with the Ludicrous upgrade that at full charge there isn't much more power but given the 15% higher current capacity of the new fuse that as voltage drops, they're upping the current to keep the power at the same level? Perhaps there's something about the inverters in the DUs that prevent more than 425KW but as the SOC drops, the fuse can now allow more current than before so that something above 410KW can still be produced.
Can someone run Powertools on a P85DL at 70% and record the power level? Is it the same as at 90%?
