Cottonwood
Roadster#433, Model S#S37
Be aware that you can't rely on an IR thermometer to tell you the temperature of a black surface. Its emissivity is calibrated at 0.95 (which is about what an opaque white surface is.) To get around this, you can use a small amount of tip-ex or white correction fluid on the point you want to measure.
I beg to differ. You want black, not white.
0.95 emissivity is what you get with a good, black, opaque, non-reflective object, like black masking tape. For better accuracy, put some black masking tape on the object. The flat, black surface of the HPWC handle is probably pretty good, but the reflective, metallic parts are really bad for an IR temperature measurement. Also, distance spot ratio is really important. For an inexpensive IR Thermometers with a distance spot ratio of 8:1, you need to be 4" away to get a 0.5" diameter measurement spot.
From IR Thermometers & Pyrometers - Omega.com:
One way to determine emissivity experimentally is by comparing the radiation thermometer measurement of a target with the simultaneous measurement obtained using a thermocouple or RTD. The difference in readings is due to the emissivity, which is, of course, less than one. For temperatures up to 500°F (260°C) emissivity values can be determined experimentally by putting a piece of black masking tape on the target surface. Using a radiation pyrometer set for an emissivity of 0.95, measure the temperature of the tape surface (allowing time for it to gain thermal equilibrium). Then measure the temperature of the target surface without the tape. The difference in readings determines the actual value for the target emissivity.
