At less than 50 mph, no big deal. At 70 mph, big deal. He was not driving 70 mph.Anyone with a 85kW pack can get 250 miles at 50 mph in cold weather. At 40 mph, even greater range.
What do you consider "cold"?
He seems to suggest that the "cold weather package" coming to Norway would actually increase the range compared to the US-spec car he was driving. (towards the end of the video). I wasn't aware that there was anything in the package that would do that (is there?). Maybe having both front and rear seat heaters means you can dial the cabin heat back a bit, but beyond that, is there anything else that could help?
So we (myself included) are paying EUR 1.275 for preheating the washer fluid, wiper blades and being able to warm our kids butts.
Cold Weather Package Improve cold-weather comfort and convenience by adding: A battery heater is included as standard equipment in all cars.
- 3-zone rear-seat heaters
- Washer nozzle heaters
- Wiper blade defroster
€ 1.275
I guess I don't qualify as anyone then.Anyone with a 85kW pack can get 250 miles at 50 mph in cold weather. At 40 mph, even greater range.
You didn't include this requirement in your initial assertion.All it takes is practice and living in the Midwest with very flat roads.
mknox, I think you are absolutely correct.
There's been a lot of fuzz back and forth regarding the "Winter package", actually around the time this test was done. That is misinformation from Tesla's side mainly, as I see it. Websites have been updated frequently. As per now you can read on the "Other EU" region: http://www.teslamotors.com/en_EU/models/options
Having three kids, and living in a cold country, I included it. So the theoretically extended range you would possibly get is the energy you'd save by not having to use the regualar cabin heat as you say.
This is also confirmed by Tesla representatives in Norway that this is more or less a "Comfort" package.
So adding more range with the winterpackage as the roporter says, is BS (IMO), unfortunatly based on (mis)information from Tesla in the first place.
I certainly hope the ventilation problem on the front side window will be solved, both with and WITHOUT the winterpackage. Otherwise it will be looked as a scam (i.e. not usable during winterconditions).
Anyway a great test though.
You are right in the fact that Model S is built for cold and warm climate. The Cold Weather package is designed for customers who experience artic winter conditions many months of the year. If the Model S battery is below freezing temperatures, the battery must be warmed before charging can begin. The battery coolant heater draws power from the main (high voltage) battery when the vehicle is unplugged, and wall power when the vehicle is plugged in, to warm the coolant and thus the battery to a temperature for charging to begin. If a vehicle is not equipped with Cold Weather Package, Model S will run the motor and inverter to generate the heat needed to warm the coolant and thus the battery to initiate charging. In this mode, heating takes longer and is less efficient than using a battery coolant heater but is still effective. Heating from the drive unit can occur in Park or Drive; it does not require a driver to be present or the vehicle to move. As with the battery heater, power is drawn from the battery when the vehicle is unplugged and from the wall when plugged.
*This feature is only used when the battery is left to acclimate to below freezing temperatures.
a) Heated second row seats
Benefits: Warm butts for the second row passengers. Reduced load on the high voltage battery relative to using the climate control heat, which means better vehicle range. Of course, range improvement will depend on driving style and how the customer usually sets their cabin climate control.
b) Heated windshield wiper cowl
Benefit: Un-freezes the wipers if snow or ice builds up on the base of the windshield around the wipers
c) Heated windshield washer nozzles
Benefit: Makes sure the windshield washer fluid sprays perfectly in super cold conditions
d) Revised windshield defrost grill
Benefit: Allows the windshield to defrost more quickly
e) Battery coolant heater
Benefit: Quicker and more efficient warming of the battery to start charging when the battery is below freezing. It is impossible to forecast warming time because it's dependent on many different factors like: ambient temperature, battery temperature, relative temperature among modules in the battery, is the car plugged in, or unplugged, what is the level of the power source, etc. Given like conditions, the battery coolant heater will warm the battery to a minimum level to start charging more quickly and efficiency than using the drive unit
We recommend this for our artic customers who park most of the time outside, but if you park your car in a garage and are not leaving the car outside in minus degrees unplugged for a longer time you might not need it. As the description states above you need to consider whether these benefits are something you personally require.
Tesla have later adjusted their info saying that the battery heater is identical with and without the cold weather packet.
Tesla Europe needs to really get their act together.
Agreed 100%. Whoever is their head of marketing/PR/communications is not doing their job IMO. Yes, I know it's hard to stay on top of things when things are moving so fast, but really that's only even more reason to make sure, and then make sure again, that information given to customers is accurate. So much better to say "Don't know" or "To be determined" than saying something that later shows out to be wrong.
What leads you to conclude that it's a position in Tesla Europe that's the problem rather than a person in California? This type of problem is definitely not unique to Europe details disclosure. As such, I'd expect it's a problem from Tesla at a higher level that impacts all markets.Agreed 100%. Whoever is their head of marketing/PR/communications is not doing their job IMO.
Looks to me they added an optional item and made it standard on all European models. No good deed goes unpunished?
It said -6 Celsius at the end of the film. That is .... let me check.... 21.2F...Thank you for the video !
A great surrogate for Quebec winter driving, including the driver's window fogging :smile:
Given your experiment, Montreal-Quebec should not be an issue under most conditions (except frigid full-on blizzards).
Does anyone know what the local temperature was when this was filmed?
Thermodynamically speaking, it is impossible for one resistive electric heater to be more efficient than another. They all have the same efficiency. You could make it more powerful, or you could better insulate the battery, but you're not going to make the heater more efficient.
A heat pump can be more efficient; but you need a reservoir to pump the heat from. I believe this is why the heater takes so much less power once the car is heated up.
