Much less than you think. Possibly none.All I am asking is what additional range could the 85 get if it was less powerful?
Smaller motors will not significantly increase efficiency. Electric motors are not like gasoline engines, where the is a significant loss in efficiency running an oversized gas engine.
Because of their very high efficiency, you could run a 250 HP electric motor at 1/5 power output, and a 100 HP electric motor at 1/2 output, and they will both have (approximately) the same efficiency and use the same power (37,250 kW) to produce 50 HP.
The smaller motor will be slightly lighter, so the car will be a little more efficient, but the gains won't be significant.
The D's gain range (efficiency) because of the different gearing in the front motor, not because of 2 smaller motors vs one large one.
