ThosEM
Space Weatherman
That is the difference of course. I freely admit that I'm on the outer edge of the market for this car. But... we just went through a brutal winter of pretty regular -20s. And the loss in range was astounding. On one very cold day I left the house with 80% charge. After a day of 130 km of drive, with admittedly a lot of short trips and with the heater operating , I returned home with 24 km of rated range remaining. 400 km my eyeball! Temperatures are floating in and around the zero mark here and even with that I normally get home showing an average consumption of 275 wh/km. Bump the batteries to 120 and it's a totally different game for this vehicle.
The origin of range anxiety is *inconsistency* and *uncertainty* about range, and that can't be addressed by any size of battery in cold weather. Please consider this: dumping electricity into a resistor for heat is *every bit as wasteful* as dumping gasoline into an internal combustion engine for locomotion. An ICE is a wonderful heater but a terrible motivator. And an EV is a wonderful motivator but a terrible heater. Electric heating and combustion motivation are both only about 20% efficient compared with an energy efficient approach. The Model S does a great job of being efficient in locomotion, but it doesn't even have a reversible heat pump, without which electricity is being squandered on resistance heating. Fixing this would be easy, even as a retrofit, and it's a prerequisite for getting the most out of a battery in cold weather.
But even with a heat pump doing the heating in moderate weather, we'd still need auxiliary heat in very cold weather. And I submit that it is wasteful to use electricity for that, and that there is no substitute for combustion to heat things when it is too cold for a heat pump to be effective. A combustion heater should be a part of any cold weather package sold for EVs. The Swedes have developed something called "biogas" that is CO2 neutral by virtue of the consumption of CO2 during its synthesis. Some Scandinavian electric buses are using biogas for heat. But propane is also a very clean-burning fuel that is easily found anywhere there are gas grilles being used. And of course it is easy to find gasoline or diesel, either of which can be burned by a "parking heater." Those are available for after market installation in normal ICE cars, and have also been adapted to EVs by some enterprising owners coping with cold weather.
Bottom line: if we want consistent electric range, we need first, a reversible heat pump for moderate weather; and second, a combustion heater for the really cold stuff.
