Owner
Doesn't this require you to "jack up the front wheels"?
To get a very accurate toe-in measurement jack up front wheels and scribe a true running line on the face of the tire. Place the gauge in front of the tires and align the pointers with the scribe lines. Then move the gauge to the rear of the tires and align the fixed end with the scribe line. On the other end loosen the thumb screws and move the slider until the pointer aligns with the other scribe line. Now read the exact toe-in on the scale. Quick, easy, & accurate. A reminder… The scribed line can be anywhere on the tire face.
The alignment figures you display DO NOT equal the inside shoulder on your tires. I'm with Zwede on this one; go to an independent tire shop and have them give you their print out for the alignment as the car is now (before it goes back to the SC). It looks a whole lot like toe out to me.
If people have a concern over the accuracy of the SC's alignment specs and these concerns are costing $1000 per 8500 miles, I would recommend the following-
Toe-In Gauge
For less than $150 delivered to your door, you and a bud can check toe with a standard ruler in less than three minutes! There is no guessing, speculation or arguing.
This will not tell you thrust angle but then that is not as critical as total toe.
