Cottonwood
Roadster#433, Model S#S37
I might also adapt my Roadster HPC to J1772 so I can charge faster if the need ever arises.
If you contact ClipperCreek, they have a kit that will convert a Roadster HPC to a J1772 wall unit.
If I've already got two Mobile Connectors and am not putting in a circuit larger than 50 amps into my house, then there is really no reason to get the Wall Connector.
Even if you get twin chargers, there's no compelling reason to use that extra capacity at home. Roadster owners posting here have uniformly indicated that 40A charging at home is adequate in nearly every situation.OK, I have a reason to get twin chargers now (and so does mknox): Sun Country Highway is installing 90 amp chargers across Canada, and *soon* (SW Ontario coming in *September* apparently). With public chargers available, the twin chargers suddenly make a lot of sense.
Which makes the HPWC make more sense.... sigh.
I would literally never use it at home.Even if you get twin chargers, there's no compelling reason to use that extra capacity at home.
Well, that's what happens when charging installation groups are "local" and only some of them know what they're doing! You end up with weird routes.It seems odd, however, that (if I were to get twin chargers) the most effective way for me to drive from Fremont to Boston might be via Manitoba.....
Anyone know if Tesla makes a NEMA 6-15 adapter?
That's really great news! I had also heard Tesla was planning some Supercharger stations along the Hwy 401 route through southern Ontario. I had planned on twin chargers already, even though I'll never be able to make use of it at home.
On a related note, it may take some serious work to get a 50 amp circuit to my garage. There is a dedicated run of #14/2 to the garage for a single 120 volt outlet. In theory, I could re-purpose that to a 15 amp 240 volt line and install a NEMA 6-15 outlet. This would give me 12 amps at 240 volts, which should re-fill my 80 mile daily use in about 9 hours. This is actually do-able and I could re-charge at entirely off-peak rates (7:00 pm to 7:00 am).
on the charging page where they discuss the adapters (http://www.teslamotors.com/models/charging#/outlet) they state officially that they will support nemas 5-15, 14-50, 6-50, 10-30 and 14-30 if that helps.
You can build your own, OpenEVSE's new firmware now allows adjusting the pilot signal, via a 1 button menu sytem.
You could set it at 12A for your 15A 240V circuit, and put whatever connector on the cable you would like.
There's no reason you have to use a 15-amp connector just because you have 15-amp wiring and breaker. You can always put in higher rated connector so you can use a 10-30 or 14-30 no problem. Just be sure to tell the car the correct charging current so you don't trip the breaker when it's charging.Anyone know if Tesla makes a NEMA 6-15 adapter? ... I did see that, but wasn't sure that it was meant to be a comprehensive list. Now that I look at it again, I think it may be.
Any word on when the HPWC will ship? I've not seen anyone post they have received theirs yet. I emailed my rep and he said it was "not shipping yet because UL approval not received".
I'm wired with a 100A service to a box for the HPWC. I can't easily attach these very large gauge wires to a NEMA 14-50 connector, so I really want to have my HPWC installed before I take delivery.
You wouldn't really want to do that anyway. You'd have a 50 amp rated device (the NEMA 14-50) connected to a 100 amp circuit which is an electrical no-no.
You could connect a 50 amp sub to the panel in the garage and run #6 to a plug if you had to.
