Hi folks,
This is weird. Not making sense. I need some sanity...
To my comment about PWM on the output from the PEM turns out to not be correct. The meter is seeing a glitchy AC component to the output, but it looks more like noise, not PWM. Here's what it looks like on the oscilloscope with and without a 6w bulb attached. The voltage is in the few mv range, moving around a bit, and about 13.something open circuit when the car wakes up.
Now, here's the puzzle. I disconnect the bulb, leaving the scope attached. It, and a volt meter in parallel, should be the only things between the connector under the car, and the connector at the PEM. But when I disconnect the bulb, the voltage RISES SLOWLY, in a typical R-C fashion. After several seconds (5+ maybe?) the voltage crosses about 10v I get an 1144 alert in the car. Repeat. Attach the bulb for a few seconds, disconnect, wait, 10 volts, beep-beep-beep. I repeated the experiment on the Motor Fan connector, and the identical R-C behavior repeats there too. Since the motor fan is is associated with the 1146 alerts, and these don't show in the cabin (it boggles the mind why not), I download the logs after. Yep, 1146s after the bulb is disconnected.
SO for the budding EE's in the group, here's the problem. If the source of the high resistance is a presume-failed connector under the PEM, that means that the capacitor MUST be on the blower motor side of that connector. R, then C. But there's supposed to only be wires between the two. Certainly no sizeable capacitor. And given that the 1144/1146 alerts are delayed, the voltage sensing must be after that capacitor. WHAT IS GOING ON?
The only thing I can think of is that the high resistance is internal to the PEM. Is there any other connector up-stream that could account for this, or any other fuse which is in line with BOTH of the fan connections, yet allows the PEM to otherwise work normally? (Note that both of the 20A blower fuses under the PEM cover check out good.)
Help?
Greg
Help?
Greg
