I purchased my roadster 1.5 back in January and am loving it.
I have put many mods including preventative PEM work.
I usually only charge 110V 15A unless I need a cooling cycle 240V 16A.
Usually Ideal range in the low 180's
The last 2 times I have changed my ideal range was in the 160's and now 159. Previously lowest was 179.
I was concerned something happening so finally pulled my log files to see what was going on.
I also figured out I was having a common problem with the GFI on the standard 110V (was tripping).
So when I pulled the logs is seems the CAC is consistent? Fine?
Just put a new plug and charge?
Or my ideal range was overly optimistic and this is the real range?
Or a reason to be concerned?
I drive it daily between 5-20 miles total and daily charge it always standard mode charge and have never driven it down below 50% capacity since I had it.
Would love to hear from any log or battery wiser folks.
How do I interpret this?
I doesn't seem to have a drastic drop in CAC - but why the drastic drop in ideal range?
What setting do you guys use in the DOS command line app to get the sheets and brick values?
date and time timestamp tag data
03/01/2020 11:21:45 | 1583083305 | DAY | odo = 10200.8 range soc = 83%, brick ave 151.125Ah, brick min 148.845Ah, min Ah brick 79, CAC 149.17 Ah
03/02/2020 11:34:40 | 1583170480 | DAY | odo = 10223.0 range soc = 83%, brick ave 151.125Ah, brick min 148.845Ah, min Ah brick 79, CAC 149.17 Ah
03/03/2020 11:34:40 | 1583256880 | DAY | odo = 10223.0 range soc = 73%, brick ave 150.954Ah, brick min 148.731Ah, min Ah brick 79, CAC 149.05 Ah
03/04/2020 11:34:40 | 1583343280 | DAY | odo = 10223.1 range soc = 73%, brick ave 150.954Ah, brick min 148.731Ah, min Ah brick 79, CAC 149.05 Ah
03/05/2020 11:34:41 | 1583429681 | DAY | odo = 10223.1 range soc = 72%, brick ave 150.954Ah, brick min 148.731Ah, min Ah brick 79, CAC 149.05 Ah
03/06/2020 11:34:41 | 1583516081 | DAY | odo = 10223.1 range soc = 71%, brick ave 150.954Ah, brick min 148.731Ah, min Ah brick 79, CAC 149.05 Ah
03/07/2020 11:37:34 | 1583602654 | DAY | odo = 10245.4 range soc = 77%, brick ave 150.726Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/08/2020 12:37:35 | 1583689055 | DAY | odo = 10247.6 range soc = 84%, brick ave 150.726Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/08/2020 16:33:23 | 1583703203 | ERR | error code 1554 8 bytes
03/09/2020 12:37:35 | 1583775455 | DAY | odo = 10277.8 range soc = 82%, brick ave 150.612Ah, brick min 148.332Ah, min Ah brick 79, CAC 148.65 Ah
03/10/2020 12:37:35 | 1583861855 | DAY | odo = 10277.8 range soc = 84%, brick ave 150.612Ah, brick min 148.332Ah, min Ah brick 79, CAC 148.65 Ah
03/11/2020 12:37:35 | 1583948255 | DAY | odo = 10277.8 range soc = 84%, brick ave 150.612Ah, brick min 148.332Ah, min Ah brick 79, CAC 148.65 Ah
03/12/2020 12:37:36 | 1584034656 | DAY | odo = 10277.8 range soc = 84%, brick ave 150.612Ah, brick min 148.332Ah, min Ah brick 79, CAC 148.65 Ah
03/13/2020 12:37:37 | 1584121057 | DAY | odo = 10277.8 range soc = 84%, brick ave 150.612Ah, brick min 148.332Ah, min Ah brick 79, CAC 148.65 Ah
03/14/2020 12:37:37 | 1584207457 | DAY | odo = 10284.0 range soc = 83%, brick ave 150.612Ah, brick min 148.332Ah, min Ah brick 79, CAC 148.65 Ah
03/15/2020 12:37:37 | 1584293857 | DAY | odo = 10284.0 range soc = 83%, brick ave 150.612Ah, brick min 148.332Ah, min Ah brick 79, CAC 148.65 Ah
03/15/2020 23:38:48 | 1584333528 | ERR | error code 1660 6 bytes
03/15/2020 23:38:48 | 1584333528 | ERR | error code 1094 6 bytes
03/16/2020 12:37:38 | 1584380258 | DAY | odo = 10315.0 range soc = 81%, brick ave 150.612Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/17/2020 12:37:38 | 1584466658 | DAY | odo = 10315.0 range soc = 86%, brick ave 150.612Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/18/2020 12:37:38 | 1584553058 | DAY | odo = 10315.0 range soc = 86%, brick ave 150.612Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/19/2020 12:37:38 | 1584639458 | DAY | odo = 10315.0 range soc = 86%, brick ave 150.612Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/20/2020 12:37:39 | 1584725859 | DAY | odo = 10315.0 range soc = 86%, brick ave 150.612Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/21/2020 12:37:39 | 1584812259 | DAY | odo = 10315.0 range soc = 86%, brick ave 150.612Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/22/2020 12:37:40 | 1584898660 | DAY | odo = 10315.0 range soc = 86%, brick ave 150.612Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/23/2020 12:37:40 | 1584985060 | DAY | odo = 10315.0 range soc = 85%, brick ave 150.612Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/24/2020 12:37:40 | 1585071460 | DAY | odo = 10315.0 range soc = 85%, brick ave 150.612Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/25/2020 12:37:41 | 1585157861 | DAY | odo = 10315.0 range soc = 85%, brick ave 150.612Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/26/2020 12:37:41 | 1585244261 | DAY | odo = 10315.0 range soc = 85%, brick ave 150.612Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/27/2020 12:42:51 | 1585330971 | DAY | odo = 10315.0 range soc = 85%, brick ave 150.612Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/28/2020 12:42:51 | 1585417371 | DAY | odo = 10315.0 range soc = 86%, brick ave 150.612Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/28/2020 12:43:05 | 1585417385 | ERR | error code 925 6 bytes
03/29/2020 12:42:51 | 1585503771 | DAY | odo = 10315.0 range soc = 86%, brick ave 150.612Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
03/30/2020 12:42:52 | 1585590172 | DAY | odo = 10358.9 range soc = 64%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
03/30/2020 17:54:46 | 1585608886 | ERR | error code 925 6 bytes
03/31/2020 12:42:52 | 1585676572 | DAY | odo = 10366.0 range soc = 69%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/01/2020 12:42:52 | 1585762972 | DAY | odo = 10376.8 range soc = 83%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/02/2020 12:42:52 | 1585849372 | DAY | odo = 10383.7 range soc = 85%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/03/2020 12:42:53 | 1585935773 | DAY | odo = 10389.3 range soc = 85%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/04/2020 12:42:53 | 1586022173 | DAY | odo = 10402.7 range soc = 84%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/05/2020 12:42:54 | 1586108574 | DAY | odo = 10402.7 range soc = 86%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/06/2020 12:42:55 | 1586194975 | DAY | odo = 10404.6 range soc = 85%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/07/2020 12:42:55 | 1586281375 | DAY | odo = 10410.2 range soc = 85%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/08/2020 12:42:55 | 1586367775 | DAY | odo = 10429.4 range soc = 84%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/09/2020 12:42:55 | 1586454175 | DAY | odo = 10435.9 range soc = 81%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/10/2020 12:42:55 | 1586540575 | DAY | odo = 10476.2 range soc = 74%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/11/2020 13:43:32 | 1586630612 | DAY | odo = 10520.9 range soc = 80%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/12/2020 13:43:33 | 1586717013 | DAY | odo = 10520.9 range soc = 86%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/13/2020 13:43:34 | 1586803414 | DAY | odo = 10520.9 range soc = 86%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/14/2020 13:43:34 | 1586889814 | DAY | odo = 10520.9 range soc = 86%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/15/2020 13:43:34 | 1586976214 | DAY | odo = 10520.9 range soc = 86%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
04/16/2020 13:43:35 | 1587062615 | DAY | odo = 10537.9 range soc = 84%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
04/17/2020 13:43:35 | 1587149015 | DAY | odo = 10578.5 range soc = 79%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
04/18/2020 13:43:36 | 1587235416 | DAY | odo = 10578.5 range soc = 86%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
04/19/2020 13:43:37 | 1587321817 | DAY | odo = 10578.5 range soc = 86%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
04/20/2020 13:43:38 | 1587408218 | DAY | odo = 10600.9 range soc = 84%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
04/21/2020 13:43:38 | 1587494618 | DAY | odo = 10600.9 range soc = 86%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
04/22/2020 13:43:39 | 1587581019 | DAY | odo = 10602.7 range soc = 85%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
04/23/2020 13:43:40 | 1587667420 | DAY | odo = 10607.4 range soc = 82%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
04/24/2020 13:43:41 | 1587753821 | DAY | odo = 10607.4 range soc = 82%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
04/25/2020 13:43:41 | 1587840221 | DAY | odo = 10607.4 range soc = 81%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
04/26/2020 13:43:42 | 1587926622 | DAY | odo = 10607.4 range soc = 81%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
04/27/2020 13:43:43 | 1588013023 | DAY | odo = 10607.4 range soc = 80%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
04/28/2020 13:43:44 | 1588099424 | DAY | odo = 10607.4 range soc = 80%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
04/28/2020 17:40:19 | 1588113619 | ERR | error code 925 6 bytes
04/29/2020 13:43:44 | 1588185824 | DAY | odo = 10615.6 range soc = 83%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
04/30/2020 13:43:45 | 1588272225 | DAY | odo = 10617.5 range soc = 85%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/01/2020 13:43:46 | 1588358626 | DAY | odo = 10628.9 range soc = 85%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/02/2020 16:08:51 | 1588453731 | DAY | odo = 10688.3 range soc = 78%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/03/2020 14:52:48 | 1588535568 | ERR | error code 955 6 bytes
05/03/2020 14:52:48 | 1588535568 | ERR | error code 1081 6 bytes
05/03/2020 14:57:50 | 1588535870 | ERR | error code 1082 6 bytes
05/03/2020 14:57:50 | 1588535870 | ERR | error code 1065 6 bytes
05/03/2020 14:57:50 | 1588535870 | ERR | error code 1081 6 bytes
05/03/2020 14:57:50 | 1588535870 | ERR | error code 955 6 bytes
05/03/2020 21:09:51 | 1588558191 | DAY | odo = 10704.8 range soc = 84%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/04/2020 21:09:51 | 1588644591 | DAY | odo = 10704.8 range soc = 86%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/05/2020 21:09:51 | 1588730991 | DAY | odo = 10704.8 range soc = 86%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/06/2020 21:19:35 | 1588817975 | DAY | odo = 10711.7 range soc = 85%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/08/2020 04:38:10 | 1588930690 | DAY | odo = 10743.1 range soc = 80%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/09/2020 04:38:10 | 1589017090 | DAY | odo = 10769.7 range soc = 84%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/10/2020 04:38:10 | 1589103490 | DAY | odo = 10795.9 range soc = 83%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/11/2020 04:38:11 | 1589189891 | DAY | odo = 10801.1 range soc = 84%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/12/2020 04:38:11 | 1589276291 | DAY | odo = 10808.4 range soc = 80%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/13/2020 04:38:11 | 1589362691 | DAY | odo = 10814.9 range soc = 80%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/14/2020 04:38:12 | 1589449092 | DAY | odo = 10814.9 range soc = 86%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/15/2020 04:38:12 | 1589535492 | DAY | odo = 10814.9 range soc = 86%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/16/2020 04:38:12 | 1589621892 | DAY | odo = 10814.9 range soc = 86%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/16/2020 18:29:25 | 1589671765 | ERR | error code 925 6 bytes
05/16/2020 19:18:37 | 1589674717 | ERR | error code 1065 6 bytes
05/17/2020 04:38:12 | 1589708292 | DAY | odo = 10838.4 range soc = 83%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/18/2020 04:38:13 | 1589794693 | DAY | odo = 10843.7 range soc = 85%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/19/2020 08:26:53 | 1589894813 | DAY | odo = 10895.5 range soc = 76%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/20/2020 08:26:54 | 1589981214 | DAY | odo = 10901.1 range soc = 83%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/21/2020 08:26:54 | 1590067614 | DAY | odo = 10907.6 range soc = 85%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/22/2020 08:26:55 | 1590154015 | DAY | odo = 10914.1 range soc = 85%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/23/2020 08:26:56 | 1590240416 | DAY | odo = 10914.1 range soc = 86%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/24/2020 08:26:56 | 1590326816 | DAY | odo = 10924.0 range soc = 85%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/24/2020 16:00:16 | 1590354016 | ERR | error code 955 6 bytes
05/25/2020 08:26:57 | 1590413217 | DAY | odo = 10949.5 range soc = 83%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/26/2020 08:26:57 | 1590499617 | DAY | odo = 10959.6 range soc = 85%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/26/2020 17:20:22 | 1590531622 | ERR | error code 925 6 bytes
05/27/2020 08:26:58 | 1590586018 | DAY | odo = 10966.1 range soc = 85%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/28/2020 08:26:59 | 1590672419 | DAY | odo = 10969.3 range soc = 85%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/28/2020 17:57:01 | 1590706621 | ERR | error code 925 6 bytes
05/29/2020 08:26:59 | 1590758819 | DAY | odo = 10975.9 range soc = 85%, brick ave 150.498Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
05/29/2020 17:15:25 | 1590790525 | ERR | error code 955 6 bytes
05/29/2020 17:15:25 | 1590790525 | ERR | error code 1081 6 bytes
05/29/2020 17:20:26 | 1590790826 | ERR | error code 955 6 bytes
05/29/2020 17:20:26 | 1590790826 | ERR | error code 1081 6 bytes
05/30/2020 08:26:59 | 1590845219 | DAY | odo = 11002.0 range soc = 84%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
05/31/2020 08:27:00 | 1590931620 | DAY | odo = 11060.4 range soc = 77%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
06/01/2020 08:27:00 | 1591018020 | DAY | odo = 11066.1 range soc = 85%, brick ave 150.555Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
06/02/2020 08:27:00 | 1591104420 | DAY | odo = 11082.3 range soc = 83%, brick ave 150.555Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
06/02/2020 17:59:42 | 1591138782 | ERR | error code 955 6 bytes
06/02/2020 17:59:42 | 1591138782 | ERR | error code 1081 6 bytes
06/02/2020 18:04:43 | 1591139083 | ERR | error code 1082 6 bytes
06/02/2020 18:04:43 | 1591139083 | ERR | error code 1065 6 bytes
06/02/2020 18:04:43 | 1591139083 | ERR | error code 1081 6 bytes
06/02/2020 18:04:43 | 1591139083 | ERR | error code 955 6 bytes
06/02/2020 19:05:00 | 1591142700 | ERR | error code 1082 6 bytes
06/02/2020 19:05:00 | 1591142700 | ERR | error code 955 6 bytes
06/03/2020 08:27:01 | 1591190821 | DAY | odo = 11088.8 range soc = 84%, brick ave 150.555Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
06/03/2020 17:42:53 | 1591224173 | ERR | error code 955 6 bytes
06/04/2020 08:27:01 | 1591277221 | DAY | odo = 11097.3 range soc = 83%, brick ave 150.555Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
06/04/2020 20:26:49 | 1591320409 | ERR | error code 925 6 bytes
06/05/2020 08:27:01 | 1591363621 | DAY | odo = 11108.3 range soc = 81%, brick ave 150.555Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
06/05/2020 17:45:54 | 1591397154 | ERR | error code 925 6 bytes
06/06/2020 08:27:02 | 1591450022 | DAY | odo = 11114.8 range soc = 84%, brick ave 150.555Ah, brick min 148.389Ah, min Ah brick 79, CAC 148.71 Ah
06/06/2020 14:56:06 | 1591473366 | ERR | error code 1073 6 bytes
06/07/2020 08:27:02 | 1591536422 | DAY | odo = 11148.0 range soc = 83%, brick ave 150.612Ah, brick min 148.446Ah, min Ah brick 79, CAC 148.77 Ah
06/07/2020 14:08:18 | 1591556898 | ERR | error code 955 6 bytes
06/08/2020 08:27:03 | 1591622823 | DAY | odo = 11178.3 range soc = 81%, brick ave 150.669Ah, brick min 148.503Ah, min Ah brick 79, CAC 148.82 Ah
06/09/2020 08:27:03 | 1591709223 | DAY | odo = 11185.4 range soc = 82%, brick ave 150.669Ah, brick min 148.503Ah, min Ah brick 79, CAC 148.82 Ah
06/10/2020 08:27:03 | 1591795623 | DAY | odo = 11222.9 range soc = 82%, brick ave 150.669Ah, brick min 148.503Ah, min Ah brick 79, CAC 148.82 Ah
06/11/2020 08:27:03 | 1591882023 | DAY | odo = 11229.5 range soc = 85%, brick ave 150.669Ah, brick min 148.503Ah, min Ah brick 79, CAC 148.82 Ah
06/12/2020 08:46:08 | 1591969568 | ERR | error code 934 6 bytes
06/12/2020 08:46:09 | 1591969569 | DAY | odo = 11265.8 range soc = 80%, brick ave 150.669Ah, brick min 148.503Ah, min Ah brick 79, CAC 148.82 Ah
06/12/2020 21:03:09 | 1592013789 | ERR | error code 955 6 bytes
06/12/2020 21:03:09 | 1592013789 | ERR | error code 1081 6 bytes
06/13/2020 08:46:09 | 1592055969 | DAY | odo = 11272.3 range soc = 83%, brick ave 150.669Ah, brick min 148.503Ah, min Ah brick 79, CAC 148.82 Ah
06/13/2020 18:44:57 | 1592091897 | ERR | error code 925 6 bytes
06/13/2020 18:44:57 | 1592091897 | ERR | error code 1081 6 bytes
