Electrify America has nothing on their map anywhere close to Albert Lea so that suggests it is unlikely to be EA.
Locate a charger | Electrify America
If they add a power wall (or equiv.), the peak power would be lower. The site would need the same power load (or a little less) but addition of one electrical gizmo. I'm not sure that would need re-authorization. The power load might also be a bit cleaner, so the electric utility might be happier about it.Yes, I imagine the permits and such include power connection requirements which will be different for a v3? Obviously, allow for higher peak power. I thought I read somewhere they were planning to use a battery pack-up (enhanced powerwall type unit?) to smooth the peak power demand in places where they are metered by peak power too, but obviously the supply connection will have to be bigger. So a different setup altogether, requiring different permits.
The existing location is really suffering. When I was through there a few weeks ago, we had to move to another stall to get decent charging. The new location can't come online soon enough. I really wonder if they'll keep the existing site active given its many deficiencies.I stopped in in the wee hours this morning. No bollards yet, but lots of equipment installed and the trench was filled. I think the transformer might even be in place, but it seemed to be a non-standard shape so I wasn't entirely sure it was a transformer.
I then circled back to the existing Albert Lea supercharger. The ramp from I-35N to I-90E was closed which resulted in a 10 mile detour. I had 10 miles remaining so I drove slow and arrived with 0 miles left on the battery. Then it took ages for the supercharger to get up to a speed over 1kW. I tried all 4 stalls and was only getting 1kW at each. Finally after about 15 minutes it ramped up to 60kW and then 105kW. I've let my battery go down to zero a few times and had never experienced this type of behavior.
I also felt lucky that the stalls were not ICEd. With only 4 stalls and 2 of them allowing for overnight ICE parking, this location is super worrisome. The new one can't open soon enough.
Hoping to use this one in a couple of weeks. Anything new?
Progress ground to a halt for the same reason it has ground to a halt at many other supercharger construction sites currently. There is a massive shortage of charging pedestals. So, lots of sites will reach the stage where everything is pretty much done except for putting those in and hooking up to the utility and then just stop while they wait for a renewed supply. Hopefully by the end of July the issue will start to be remedied.Not sure why progress has ground to a halt this site.
