It's due to battery aging - mostly calendar aging. Our 2018 with 200,000 miles was 310 miles at 100% when new and is now at 278 miles at 100% - a loss of about 11%. That would put me at about 222 miles at 80% - the same as you.
You can try the recalibration song and dance, but I doubt it'll do much good. Best practice for maintaining an accurate battery indication is to occasionally let the battery sit overnight at a lower state of charge (20% will do the trick) and also sit overnight at higher state of charge (90% will do the trick). Be sure Sentry Mode is OFF so the car can actually sleep.
There is nothing at all that says that you need to in any way, shape or form adhere to that advice, so if you feel you dont want to do that, you dont need to.Not to hijack the thread but I'm kind of disappointed with Tesla's new advice of 80% for daily driving. The performance model is noticably different at 80 vs 90 SOC.
Although I wonder if Tesla can see your charging habits and deny warranty for not following recommendations. There does not seem to be any precedent of that happening yet but I suspect it could be possible.There is nothing at all that says that you need to in any way, shape or form adhere to that advice, so if you feel you dont want to do that, you dont need to.
I was thinking maybe there is more data that supports more range loss pushing to 90 more often?
My 2018 M3 AWD has the same number as well. It is also the same numbers my 3 other coworkers' 2018 M3 AWD. We all bought together within a few months between August 2018 and Nov 2018. About 10% is right. Although the actual range is even less with Tesla's range estimates. My brother in law Mach E could actually drive more than the range it shows. For my M3 or MX, it had never once in 5/6 years that the range loss in the display is less than the actual range driven. If it's like 85 degrees out and I am driving 60 mph and not going uphill too much, I could get close to it.For corroboration, my 2018 with 42k miles has virtually the same range numbers as yours, which points to calendar aging.
This is expected, so not any indication of "not doing good" for a 5 year old EV (to have a reported roughly 10% range loss).
There is data (search for all the threads and posts about degradation). Generally lower is better. But 80 vs 90 is of minimal difference in degradation. The biggest reduction in degradation is staying below about 55%.I was thinking maybe there is more data that supports more range loss pushing to 90 more often?
Assuming you have AWD (not specified) you’ve lost about 12% which is fine.I charge to 80% and that used to get me to aprox. 255 miles of range (I do not remember exactly). Now it only goes to 223 miles. Is it because of an update or is my battery not doing as good? 2018 Telsa 70k miles
Since the 18 M3LR got a range bump to 325 shouldn't that number be used for degradation calculations? I have the 18 M3LR also and I'd like to know.It's due to battery aging - mostly calendar aging. Our 2018 with 200,000 miles was 310 miles at 100% when new and is now at 278 miles at 100% - a loss of about 11%. That would put me at about 222 miles at 80% - the same as you.
Yes. Actually use 332 miles or so (77.8kWh/234Wh/rmi) to be more accurate.Since the 18 M3LR got a range bump to 325 shouldn't that number be used for degradation calculations? I have the 18 M3LR also and I'd like to know.
