just hit 446kw
eta 91% soc at 81mph
Nice job yo mama.
Just 9kW off of the P90D Ludicrous and with a chance to even cut into that margin.
I had a good feeling about Ludicrous
just hit 446kw
Just out of curiosity, what happens to power delivered from the battery after it hits the above referenced max number? Does it stay there or does it decline with speed (against back emf)?
Okay, my layman's perspective is that the best performance comes at 90%+ SoC. Ran the same test on the way home at 69% SoC and maxed out at 432kw (which is still better that the prior 425kw from the other day, but still). FWIW, I did take the time to warm the battery up via max power before recording anything today. Who knows if that made a difference. I am also virtually certain that I'll be able to coax some higher numbers from the car once I get it back up to 90%+ SoC. The downside is that, if I'm right, our peak performance numbers won't last *too* long because I burned through the first 9% SoC pretty darned quick. That only got me like half way from San Jose to Fremont.
Very flat output with no obvious peaks. However, it's a very short run too. A longer run from say 50 to 80 would really be helpful and I could overlay my own 50 to 80 runs that I did based on the earlier video. Also, it looks like it took about 750 ms to ramp up from cruising to full power. I'm going to guess that you had family in the care and didn't stomp the pedal. If you did, it should take about 200 ms to go from cruise power to full power.
446KW = 598 hp at battery = 538 hp at the wheels if we see the same 10% loss that I see from battery to wheels. Very close to P90DL.
which is 100% consistent with my initial "gut feel" of this upgrade.this is good, real good. Should pull hard at high speed and is faster at lower SOC.
Problem s my center still has no info on dates.
That is not exactly correct.Somewhere around 90-93% SoC, the battery reaches its maximum Voltage. If we take the simple model that there is a maximum current, and the maximum Voltage is reached a little over 90% SoC, then maximum power (Volts * Amps) is also reached a little over 90%.
Seems like we have enough data now for people to make fairly informed decisions on whether to fork over the $5K. I'm impressed by the results and will go for it when it comes to this area. With any luck I figure I'll be enjoying the upgrade by around my first anniversary with the car. That would be cool. Get to enjoy it all over again.
