Mark77a
I'm positive that your VDS motor temperature readings are accurate, so when it was reading 103'C I'm certain it really was 103'C and not a mere 55'C given the hot PEM, ESS and ambient temps.
It is possible that there's an elementary programming cock-up in the temperature conversions used for the graph scale . . . Its also possible that the actual stored temperature readings are raw integers recorded in Fahrenheit because its more granular than centigrade. Here's why it could just be a bug :-
Correct conversion C = (F - 32) x 5 / 9
But its possible the programmer has munged this up and got the numbers back to front, ie :-
Dodgy conversion C = (F x 9 / 32) - 5
Why do I suggest this dodgy formula? Because it just so happens that if you plug the 103'C temperature into the dodgy conversion formula you get about 55'c!!
EG, supposing the 103'c temp shown was actually rounded up from, say, a correct integer Fahrenheit reading of 215'F. Plugging it into the dodgy formula would yield the faulty 55' C as shown on the graph plot ..
ie, ( 215'F x 9 / 32 ) -5 = 55' C !!
Of course, having more data samples would either substantiate this or merely show my debug brain is clutching at straws. But there does seem to be a problem with the motor temp recording / conversion ... and I have spent a lifetime debugging software from machine code upwards :biggrin:
Yes, well spotted a fine bit of reverse maths !!!!
I am beginning to agree with this ... (pity, as motor running at 55 deg c rather than 103 deg c feels, well more cool and reliable ) .. I am not sure if TeslaGLoP is still supported > TeslaFlux I am guessing Doug George is Doug_G ?
If so Doug, any suggestions ? is this a simple fix ? (I wish I could offer some help on this but I'm just a mere mech eng )
