strider
Could this just be a rated/ideal difference? Maybe the 31mph number is ideal and Francis is set to rated? Rated miles take more energy than ideal miles. I have mine set to Ideal and will check it's charge rate tonight.
I was told that cars with only one charger take quite longer for all charges compared to those with dual chargers. The mechanics in the Tesla Center in Queens told me, that at their NEMA 14-50 outlets, the singe charger cars take almost 40% longer to charge than those with dual chargers (at the same outlet). It has to do with the fact that in the master-slave-configuration of the dual chargers, they even charge quicker if only 5 or 8 KW are provided.
Agree. If this is the case, then the whole charge calculator on the Tesla site is completely misleading. I would seriously doubt this is the case. (And I can't think of a real reason why it would be the case). I don't doubt that what you were told, but it just doesn't make sense to me nor does it jive with the very nicely designed charge calculator featured by Tesla themselves.This seems contrary to previous info. If this were true, the twin chargers would be a 'must-have'.
Adapter Guide on the same page shows 5 mi/hr on 110V/12A but I'd bet money against that. Most I ever saw was 3.Single charger is 31mi/hr on 240volt. Dual charger is 62mi/hr but requires HPWC. Says so right on their page. http://www.teslamotors.com/charging#/highpower
It depends on the acutal incoming power. A real 240V at 40 amps will get 31 mph, 220V or 208V won't. Same with 120V, 110V or 108V won't. Cinergi has a video here.
Correct, but Francis has 235v per his picture, which would be just over 30 mi/hr of charge for him. The point of the post is that the indicator on the dashboard as to how many mi/hr of charge you're seeing is incorrect. Mine still shows 20 mi/hr @ 243V 40/40A, but 1 hr 10 min remaining with 207 mi of range.
And everyone's double checked that they're not set to projected because that can make the numbers look odd? If that's the case, the next thing to do is check the actual line voltage. If the line voltage isn't 240, then the the display is only showing the type of plug and extracting the voltage from that. The older software appears to show the real incoming voltage but perhaps a bug was introduced in the new software.
I do not see how one would get 31 miles per hour. At 240volts and 40 amps that is 9600 watts. W e lose about 10% in charging losses so we are down to 8640 watts. If you use 350 watts per mile that is about wt miles an hour. Maybe in the smaller Roadster but not in the Model S.
OK, here is possible a bit more information. I drove it down to about 150 miles range remaining today. Then, I started charging. A few hours later, I checked. This is what I see. I am parked outside and it was about 44F so I wonder if temperature has anything to do with it. Have others who have their cars in their garage see different rates?
By the way, thanks to everyone for helping to figure this out.
Francis, go into the car's settings and change your mileage from "rated" to "ideal" and it will show it properly. There seems to be a bug in how it's calculated when you use "rated" mode.
I think when it shows 40 / 40A it's giving all the juice to the battery; I suspect it would show less if some power is being diverted to heat etc. I've been charging 100% outdoors and I've always seen 68 / 69A (don't know why it says 69A because I've always charged from 70A sources).
My understanding is that folks above have concluded that with 4.0 (and beyond) (a) you have to have the setting set to Ideal range for it to show 31 mph charging for 240V/40A and (b) people are calling it a bug that a lower number is reported for the Rated range setting.
What I'm having difficulty understanding is (b). Why do people consider this a bug?
