nwdiver
Looks like Aluminum Wire! Requirement is #3 copper for 80 amps!!! This is specified in the manual!
The copper barely fits in the lugs. I don't see how you can properly terminate aluminum wire in the HPWC for 80 amps!
Ampacity Charts
Also Aluminum needs to be re-torqued more often than copper, and it tends to get corrosion at the terminations which will overheat if they are pushed to their max. I don't see any anti-corrosion material applied to the terminations (Noalox)
You can use Aluminum Wire... as specified on page 10.
I ran 2-2-2 triplex to my HPWC. 2-2-2 was ~$0.70/ft vs #3 copper is ~$4/ft for 4-strand. For a 70' run I saved ~$200. Everything is outdoors so I'm not worried about a fire I wouldn't run Aluminum wire through walls...
I think I will inspect my HPWC... it's been out there for >3 years now no issues.
