That's what Jerry saidWhy not just use the 85 battery pack and software limit it to 70 kwh? That's what I think they did.
In typical tesla fashion they will announce the 100kwh pack after they have real world data on these new cells.
In that case, why wouldn't the 70D pack be 14 modules of each 6 series of 70 cells? It doesn't simplify manufacturing, but at least the math works out.Considering the following :
85 pack is 16 modules of each 6 series of 74 cells. Total is 402V and 7104cells
60 pack is 14 modules of each 6 series of 60 cells. Total is 352V and 5040cells (not sure about that one)
The 240-mile range is the real puzzle. It just doesn't make sense.
The 85D has an advertised horsepower of 422 HP or 211 HP per motor. The 70D has an advertised horsepower of 329 HP or 165 HP per motor. Power in a resistive load is V[SUP]2[/SUP]/R. If we use a resistive equivalent for the motor (excuse handwaving), then the power should scale as Voltage Squared. The Voltage ratio between the 60 and the 85 was 14/16 (module number) or 7/8.
211 HP * (7/8)[SUP]2[/SUP] = 162 HP
That is close enough for me to bet on the 70D having the same number of modules as the 60 (same pack Voltage as the 60) with either more cells per module or improved cells. My wild guess would be more cells per module to transform the 60 battery to a 70.
If we see a near zero State of Charge Supercharger charge rate on the 70D of 105 kW, then the pack Voltage in the 70D is the same as the 60. Initial charge rate in both the 85 and 60 were about 120 kW and 105 kW and limited by the 330 Amps max on a Supercharger. 105=120*7/8
Assuming Tesla fit the 85kwh pack and software limit it to 70 (yes margins matter, but so does improved efficiency and product rationalisation), would that mean that you could always do a full charge as that would only charge 70 of the available 85kwh capacity? The knowledge that you could pay (yes with a premium), for the extra 15kwh would be attractive and "ease the entry point". I wonder what proportion of the 40's still are 40's and how many upgraded to 60?
did a "full charge" just put 40kwh into the battery so doing a reduced 85% charge wasn't needed to preserve longevity of the battery pack?
Or probably what I should have asked was; with the 40kwh version, did a "full charge" just put 40kwh into the battery so doing a reduced 85% charge wasn't needed to preserve longevity of the battery pack?
The right part of the slider on the 40 is inaccessible out unless you pay for the upgrade.
You can't set it to "full charge". (You can't set it to 85% charge either).
Imagine a 60, and never moving the slider past the 66% mark. That's exactly a 40. There isn't any indication in the car that it has a full charge at 40. Even the little battery icon will only show a partial charge.
in other words they are letting supply shift to new cells. like they did now for performance seats (Limiting it to one car- then to all)Typical? What's the precedent here?
Here are similar situations:
- AWD (Getting it ready for X)
- Alcantara Headliner
- Old performance seats
- New Performance seats
and probably somethings I can't remember
I think "I don't know" is the only right answer :tongue:
in other words they are letting supply shift to new cells ...
You weren't implying that they were supply constrained - you were implying the were Guiney-pigging untested new hidden technology on the 70 until they get real world data.
They've never done that before.
On every announcement people hope and speculate that they are using some magical never-before published technology for scenario X, Y or Z, which is possible that they may do one day, but there is no prior history of them doing that.
Hmm - I wonder what the 70D screen shows?The right part of the slider on the 40 is inaccessible out unless you pay for the upgrade.
