To be clear, Homelink works for me from 75' or more away no problem. My BMW had roughly the same range, perhaps a bit more. My request is for the button to present when xx feet away from door so I can touch it and open. Now to open far enough away I need to touch 'H' then touch the door.
Does anyone who backs into their garage have a problem with the door not opening? I assume the xmitter is in the front of the car since that's where you put the remote during training.
I haven't had any luck with my Craftsman garage door opener. I have two transmitters and neither worked placing them in front of the bumper - even with the car in the garage. I'm wondering if I have to get a universal Homelink adapter kit to replace the out-of-box one.
I just went out and tried this for you. Big problem. Range isn't good enough. Best to get some others to try it as well, as there might be something wrong with my car. My Homelink seems to have poor range even when the car is aiming at the door.
@dsm363 - Workaround: How 'bout retrain your homelink about 40ft away from your garage door? Thus it would present around 50ft away.
Anyone experience any difficulty pairing with the garage door opener?
Mine failed despite saying all steps were complete. The car shut
down - no computer, no dash, no going anywhere - then mysteriously
rebooted itself a couple of hours later.
Remote does not work and the service team is scratching their heads.
Any thoughts out there?
+1 to this. You can also add some length to the antenna. I had some of this: 1555 that my dad gave me and simply cut about 2 feet of it. I then stripped some of the insulation off of the end of the antenna wire (purple wire in pic below) and the wire I had and twisted the ends together. Ran the new wire up and tied it around the support. Range is MUCH better now. I was having poor range from all sources - Jeep, Roadster, and Model S homelink, even the remotes that came w/ the opener wouldn't work very well.Im getting around 75-100 ft for my gate and around the same for the garage.
Again, if you have an antenna hanging off the back of the operator, try changing directions like the old analog TV days .... it really helped mine (this is with previous vehicles).
Has anyone yet tried this and confirmed?@dsm363 - Workaround: How 'bout retrain your homelink about 40ft away from your garage door? Thus it would present around 50ft away.
