Zapped
Model S - PURE EV
Unclear what EVSE you are using? Have you ever got over 40 amp at the location you are at? etc, etc details vs vague statement.
0F is certainly it. Also may be road based on conditions (wet, snowy, etc extra friction). Unclear what all heater settings (temp, fan, etc) you were using. I've experienced pretty low range at 14F
Clipper Creek 90 provided 69 amps with 2012 MS dual chargers. I see the LR+ specs indicate 48 Amps. 40A = 20% less. No biggy, just takes longer
Road conditions were bare & dry. Auto heating setting is much better than 2012 MS. was set at 70F. Probably should just turn the heat down. I'm sure winter tires don't help (Pirelli Sottozero )
