No. It would make the front page. Although I suppose at least one person has tripped over the cable.I'm curious to see if there have been any injuries related to charging recorded yet.
I'm curious about lightning storms, eg. when plugged in at home, is there an instinct to run and unplug from the grid ?
Yet the actual outside shape and design of the plastic connector head is practically identical... for instance the Supercharger connector does not have an extra o-ring or seal on the outside. Yet the HPWC warns against allowing rainwater to "run along the length of cable and wet the ...charging port." and the Superchargers do not.
True, but it's obvious that the 14-50 side will be far more sensitive to rain than the charge port location. What's needed is a cover for the charge port and handle.
The OP was asking about Supercharging in the rain, and superchargers have no "outlet side" connection. They are hardwired, much as a HPWC is, thus the concern for either would be at the charge-port end. Hence my comments regarding the guidance from Tesla on such.
Agreed, but that was answered in the first few posts of the thread, the thread has veered somewhat off-topic
I believe that's incorrect. Look at the exact quote I copied from the HPWC manual:
Look at the parts I bolded. They discuss both the outlet (i.e. the 14-50) as well as the charging port,
The Faraday cage demonstration at the Boston Museum of Science is always fun:I occurs to me that when I started this thread I left off part of the thing that got me thinking about electricity and water.
Several years ago I worked at the late, great Hansen Planetarium in Salt Lake. We had a program there called the ZAP Show. Part of the program had me and other staffers standing bare foot on a water covered aluminum plate which was hooked to a power source which supplied over 2 million volts of electricity (at very, very low amperage). When the thing was energized mini bolts of "lightning" would shoot out of whatever body part was highest (usually fingers from hands held overhead though one guy would tip his head back and the bolts would shoot off his tongue).
The device supplying the power was (wait for it)... a *Tesla" coil.
