This is something I have been working with service on ever since I purchased the car. About one in every 10 charges, the amperage will drop to 30 from 40 and in about the half of those cases, you can't manually turn it back up to 40 without unplugging and re-plugging the car back in. They've swapped onboard chargers twice and replaced the charging port. I am currently on a loaner UMC which they wanted me to try, but as I just informed them, ever since I switched to scheduled charging, the amperage drop has not happened. They want me to try the scheduled charging for a little longer before going back to instant charging with the loaner UMC to see if the drop happens again. It should be noted that VisibleTesla does record the amperage drops very nicely so you can go back and see when the 30amp drops happens. Again, to my knowledge from those logs, it has not happened on scheduled chargers.
I will say that I have a very strong 240v service @ 200amps. Electrician and utility both did not find anything wrong with the wiring or the service. I do run multiple servers in our data center which pull quite a bit of power, but those are going 24x7. But with the comment someone made about a light-switch affecting the charge, it really could be anything used daily that triggers it; ie. dishwasher, washers, dryer, furnace, etc.
As far as real world affects, it becomes a problem when you are expecting a certain charge level when you go out in the morning and it isn't finished. As with most on here, we know the worst thing we can do to the battery is leaving it at higher SOC for extended periods of time. And adjusting the charge schedule to be earlier, would mean that would be the case in the majority of instances.
I wish there was a more definitive answer for this because it looks like I'm not the only one experiencing the trouble. And I feel for the services center because they keep "asking corporate" or "contacting the engineering team" and there doesn't seem to be any useful help on those fronts (as evidenced by my 3rd onboard charger). I only had a pre-v6 release for about 2 weeks of ownership. Yet, I did not experience the amperage drop at that time when statistically I should have seen it at least 2-3 times.
