I've got a perfect install of a 80 amp HPWC at Parents Motel. It's on a 75kW transformer. Fed by 2/0 wire to the breaker box, from breaker box 2awg to the HPWC. Thought, during the summer when the Motel was open, the current limiting from 80 to 60 was due to voltage drop or something from the Transformer. Since the Motel had 4x200 amp drops from this transformer, then, 2 more houses with 200 amp drops from it. Well, now it's winter, Model is Closed for winter. Power usage for the Motel is next to nothing. Just two houses that have intermittent electric baseboard heat.
The HPWC is STILL being limited to 60 Amps. Though, during the summer, it would take only seconds to get limited from 80 to 60. Now, it takes about 30 seconds to a Minute
Disappointing.
Also, at my home, I installed a HPWC for the rare times I need 80 amp.
Not sure what my home transformer is, it's shared by a number of houses though. HPWC is literally opposite side of the wall as the breaker box. Connected to breaker box by exactly 14 inches of 2awg. Breaker box is connected to the meter 5 ft away with 2/0.
Charging voltage starts at 242, at 40 amps drops to 220, and stays at 220 all the way to 80 amps. It will maintain voltage at 220 at 80 amps indefinitely. After about 5 minutes it will drop it down to 60 amps, despite no voltage fluctuations or changes what so ever. And it's not a matter of overloading the utility. I could maintain charging at 60 amps last summer, even with the car charging at 60 + Electric dryer running + Air Conditioner + The other 5 houses on my transformer having there AC's cranked too. Voltages are slightly higher during winter here (no AC usage), limiting still occurs.
This feature needs to be made OPTIONAL!!! Or give a option after a warning screen and waiver of liability check box to disable the limiter function due to "nuisance tripping".
