TaoJones
Beyond Driven
Well, this bodes well for red light and stop sign recognition this year at least as was previously teased. Here's hoping for another October surprise.
So many SCs are empty while on the road that I can't yet get excited about the SC heads up referenced above - although I can see how it would help many in the denser areas and at peak times. Thing is, if you need, for example, the Barstow SC, then you need the Barstow SC. Planning ahead at Needles or at Cabezon only gets you so far. Still, more and *correct* information is better than less.
Hopefully at some point they'll code in a pop-up alert for when the routing changes otherwise without any notice whatsoever to a different or the previous SC. Often this is only manifested as an upcoming exit without indication that you've just been routed in reverse. Actually, the persistent/annoying reverse case is fairly noticeable - it's the lateral or alternative routing that can really trip you up. No pun intended.
