I doubt we'll here much about this from Tesla and I'm pretty sure the owner will be told to keep quiet and Tesla will replace their car. They can't afford negative press like this going wild.
It's hard to tell whether the battery was involved in the fire. You get high temperatures from burning plastics, transmission oil, etc.
- - - Updated - - -
Quoting from an article: "It is not possible to extinguish electric car fires with water, so the fire department contained the area surrounding the fierce car fire, and used a special foam to get the fire under control."
Obviously, water is the correct way to extinguish the fire, so it does seems as if the fire departments hesitation to extenguish the fire with water did contribute to the extent of the fire. Apparently they just let it burn while they tried to get what they thought was the proper means to extinguish the fire.
The fire department did okay, but there is potential for improvement. Water is the correct firefighting method. See page 20 here: https://www.teslamotors.com/sites/default/files/downloads/en_EU/model_s_2014_emergency_response_guide.pdf?1512Firefighters avoid spraying water on any fire that has live electrical lines in it, to avoid electrocution. In my area, they wait until the power company has turned off power to a house before fighting a house fire. So even though this was a car fire, it wouold be considered an electrical fire by the fire department.
Funny. I was going to mention the same thing about those wheels.Oh you cynic
I'm not sure Tesla will replace it, the fault was clearly due to the aftermarket wheels
Anyway glad no one was hurt, and the fire brigade did the right thing. At the end of the day it's a car and replaceable.
However, if indeed the battery pack is built to direct fire outward, it doesn't look battery related.
The fire department did okay, but there is potential for improvement. Water is the correct firefighting method. See page 20 here: https://www.teslamotors.com/sites/d...odel_s_2014_emergency_response_guide.pdf?1512
I'm interested what improvement are you seeking?
if you suspect that the battery is heating, use large amounts of water to cool the battery. DO NOT extinguish fire with a small amount of water. Always establish or request an additional water supply. Always establish or request an additional water supply.
Battery fires can take up to 24 hours to fully extinguish. Consider allowing the vehicle to burn while protecting exposures.
Tesla said they will investigate.... let's hope it's something like a lit cigarette.
One improvement would be to know that you can in fact put a lithium battery fire out with water and not report to the media and the general public information to the contrary thusly perpetuating ignorance that may be slowing down the adoption of BEVs.
