I am surprised they key worked. As far as I know the keyfob, key in the rear light cluster and button in the cabin all do the same thing - trigger the solenoid that opens the catches for the trunk, I dont think the key does anything mechanical - happy to be corrected.
I have not been able to open my trunk all week, no noise of a mechanism trying to work - bit of a problem as my mobile charging lead and warm winter jacket are inside. I have been advised to run warm water around the rear light cluster but thats not worked so far.
Planning to make some space in the garage today for the Tesla so it can properly thaw out.
Nikki Gordon-Bloomfield intends to write another article and is looking for EV's that are used in very cold environments (apparently our -3 Deg C is not cold enough for some people). If you have a suitable car can I suggest that you contact her?
sure... are you driving an EV in this?We just went through a stretch for 2 weeks of daytime highs of -20 Celcius - that cold enough for ya?
Hey Doug, I wash my car IN my garage which never goes below freezing. Your free to come over if you like, although by the time you get it back to your place it will be dirty again. Such is winters in Ottawa. Sometimes it seems like there's more salt than snow on the roads.
Right now it's clean, and it's probably going to stay in the garage for a while.
Probably best although I imagine it will be tough going back to the ICE age...
Hi : I am located in Toronto and we had around 6 cm of snow and it is around -10. I installed four Hankook snows and my roadster handles fine and especially up steep icy hills without spinning. However the slush does get in the door sills. Regards MitchI have had my Pirelli winter tires on for a few days now and thought I would share how the Roadster handles winter in Lethbridge, Alberta.
The tires have great grip - and the traction control works very well with the Roadster - the tires don't spin! (unless I turn off the traction control and I have fun making donuts for a bit!)
Compared to the only other sports car I drove in winter - a BMW - the tesla handles better, grips better, and feels solid.
If the snow pile between the tires gets too high - you do become a plow unfortunately - but for me all main roads are fine (where the snow has been packed a bit) - in residential streets where snow does not get cleared I get to listen to the snow rubbing against the bottom of the car - but no real problem.
I am going to see if I can get more 3M film added in the door sills to protect the paint from sand, rocks, snow where it enters.
Here's a few pics to share:
Once my Roadster arrives (hopefully next week), I'm going to get the additional armour coat applied (as per Kevin's pictures) to the door sills...I'm sure this will help make it easier to clean off the sills without scratching the paint.
This is my first winter driving the Tesla.
We have had one snowstorm so far (Minnesota). My wife and I were eager to try snow driving, so in the middle of the snowstorm we took the Tesla out for a test.
When we started out we had just over 4 inches of virgin snow. We live in suburbia, and no plows had yet been through the neighborhood streets, although some vehicles had, so you had a mix of chopped up snow and virgin snow.
We do have the winter tires.
No issues with traction. I was actually quite surprised at how good the traction system was, no sliding whatsoever.
If the traction light had not come on I would not have known it was on.
We did a number of errands an returned a couple hours later.
Snow debri between lanes on streets that had been plowed posed no issues. You could on occasion hear chunks of snow hitting the bottom panels.
In our neighborhood the streets were still not plowed and we were up around 6 inches of snow. Temp was near freezing so the snow was very wet and clumped easily. In the unplowed backstreets we did run into an issue of snow getting jammed up into and sticking in the wheel wells to the point where the wheels were actually difficult to turn.
I have not experienced this at any other time. I am hoping to get a chance to test it in 6 inches of dry snow and will report back.
On plowed streets, the Tesla handled better than any other car I have driven in the snow.
It's above freezing today. I tried opening the trunk; it sounded like it was trying (some solenoid clicking noises) but it wouldn't open. Key didn't work, either.Mine wouldn't open again this morning (23 degrees F). Key also didn't work. [...]
