ICE cars also rev high before shifting when accelerating hard and high RPM = low efficiency.
Coasting lowers your average speed over the stopping distance, so less energy is expended over that distance than if you maintain your speed up to the stopping point. If you wait to use regen until you're at the stopping point, you use twice the energy getting there than just coasting. You still have all of the initial kinetic energy, so if regen was 100% you would use the same amount of energy as coasting, the original kinetic energy. You do get there faster, though.My wh/mile is exactly the same whether I accelerate nice and slow up to x speed or do full on ludicrous launches. What kills my wh/miles is braking...even regenerative braking only recovers about 60% of the energy. That's why I start coasting as long before a stop as I can so that energy is scrubbed off in air resistance and tire resistance.
Ah, I recall from Intro to Physics:I think the theory of special relativity has to kick in at some point once the velocity approaches the speed of light.
At least that has been my experience...
This is consistent with ICE findings from BMW testing done some years back when they were evaluating optimal fuel efficiency in acceleration in connection with meeting fuel economy standards. I do not have the data they released anymore but i clearly recall the results: accelerating at about 2/3 throttle produced the best fuel efficiency. At the time teh test was made with both then-current production diesel and gasoline models, which astonishingly (to me, anyway) showed the identical 2/3 throttle for best acceleration efficiency. They also demonstrated another ICE point made here that the most efficient thermodynamic cruise is maximum torque. The latter point totally ignores aerodynamics, which are more important than are thermodynamics above, IIRC, 80 kph.This is why you have to have efficiency maps and drive cycle models to simulate what the actual losses are. The MEs here are correct in that theoretically it takes the same energy to reach a given speed regardless of acceleration rate, but real powertrains are rate dependent. For ICE vehicles, best efficiency is generally to apply 80-90 percent throttle in a relatively tall gear, as best brake specific fuel consumption (BSFC) is generally reached with an ICE running nearly unthrottled. Accelerating slowly by feathering the throttle in that case takes more energy, ignoring the extra amount of time you spend at speed and the increased aero losses that causes. For electric vehicles in general, the efficiency maps are much flatter, with less variation. Below is an efficiency map of a Parker Hannafin GVM e-vehicle PMAC motor; the dark red is the highest efficiency; the blue/purple is the awful region. You can see that high load at low rpm isn't good, but as speed increases, there's a large region where efficiency is pretty constant -- unlike the extreme variation with an ICE. Really low loads are bad as well. It means in practice you can accelerate relatively quickly with an e-vehicle without it having much effect on your range, unless you're playing urban warrior in city driving and the quick acceleration followed by rapid braking just means you spend more time at maximum speed, where the aerodynamic losses get you.
Why do I get tired running half a mile but not if I walk 5 milesI'm trying to understand the physics of why accelerating rapidly uses more energy than a more gentle acceleration?
Is the motor/inverter less efficient at high current?
That's speed (and doughnuts) not acceleration.Why do I get tired running half a mile but not if I walk 5 miles
It depends on what percentage the periods of hard acceleration are of the total trip. If you're a lead foot and the lights are timed badly on a short trip, it can make a difference.I have seen EV reviews and people saying that driving hard will lower range, but in my experience, driving hard (accelerating quickly) has very minimal affect on range (assuming limited use of friction brakes). To me, what really affects range is cruising speed. My i3 is very sensitive to this. It has a 22kWh battery and I can zip around as much as I want with the range hit not noticeable. As soon as I get out on the highway, I can immediately notice the range drop if I go fast and a range bump if I take back roads and go slow. The i3 range meter is very dynamic in that it will fluctuate the remaining range up and down while driving.
Do you have a lead foot in the volt? The losses go up with the acceleration squared, so you really have to abuse the accelerator to see the big difference. In general the acceleration period is so short that it make little difference to a typical trip.It has virtually no effect on the Volt's range in urban settings with lots of stoplights. 5% maybe.
Now on the Cadillac or ZR1, it's like 50% difference. If you make boost, the gas needle moves like a tach needle.
But the OP's question wasn't how much, but why.
Not really related to this thread but a nice drag race between i3 REX and Gen2 Volt. i3 BEV would have been a different story (1 second faster than REX):
That is only if the i3 BEV could actually make it to the dragstrip, race, then make it back home in Texas. That is a serious consideration.
Some things to note. You see the power to weight by looking at the trap speeds. The BMW wins the power to weight war.
The ETs are tied into the 60 foot times. The Chevy only gets a good launch the first pass. Driver error on the next two. You need to pedal a 2016+ Volt for best results.
The Chevy gains 16mph between the 330 and finish. The i3 gains 14. This means the Volt might catch the i3 no matter what.
The Chevy always gets it's nose out front at roughly 30mph. This is why the Volt feels good in urban traffic.
Coasting lowers your average speed over the stopping distance, so less energy is expended over that distance than if you maintain your speed up to the stopping point. If you wait to use regen until you're at the stopping point, you use twice the energy getting there than just coasting. You still have all of the initial kinetic energy, so if regen was 100% you would use the same amount of energy as coasting, the original kinetic energy. You do get there faster, though. On the other hand if you regen down to 1/2 speed initially, as opposed to a linear ramp down, maintain that speed to the stopping point and then regen to a stop, you use only 1/2 as much energy to cover the stopping distance. The rest goes back into the battery at whatever the efficiency of regen is. This is a consequence of power going up as the speed cubed. At 1/2 speed the power required is 1/8. Kinetic energy is being dissipated much more rapidly at the initial speed. By immediately bringing the speed down to 1/2, 3/4 of the energy is captured and the car continues on at the much lower power level. 1/2 of the original energy is used to maintain this power level to the stopping point so 1/4 of the 3/4 is still available. 1/4 of the kinetic energy is still in the car and can be captured by regen. Half goes to getting the car to the end and half gets recaptured by regen. The regen half is subject to the regen efficiency, though.
If it's cost savings, not hypermiling, you need to consider time in the equation.
While it's not physics, it is significant or we would all drive 55 in the slow lane.
What I was saying is to use as little braking...even regen braking as possible will be the most efficient for whatever average speed you're going. In you're example, it would have been even more efficient to have never sped up to speed x and then slow down to 1/2 x. You would have been better off accelerating up to speed 1/2 x without exceeding it.
