I did notice an increase in speed. I only charge at night using the cheaper rate 12-7am and looking at the Stats app, it put in a fair amount more than the previous charge cycles that took place the nights before which would indicate it only started doing this recently. Stats shows a charge speed usually hovering around 9-10 miles/hour now says 12 miles/hour when at 13A. See below for the increase compared to previous sessions:
As you can see, I usually get just over 13-14kWh added over the 7 hour charge window which makes sense - 225V x 10A x 7 hours = 15.75kWh so that figure adds up if you assume some losses. This time this was more like 18-19kWh.
I've dropped it down to 10A as I've read elsewhere it's best not to got full power for extended periods of time but thought I'd bring it up since it automatically went to 13A without notification and I haven't seen anyone else mention it. This could potentially be a bad thing in terms of increased risk of damage to the plug/cables involved let alone the increased fire risk.
