I charge with a J1772 and the adapter. I've noticed that when I disconnect the J1772, the locking mechanism holding the adapter in the charge port unlocks. Unless I pull out the adapter within a few seconds, the lock engages again and the adapter is stuck. Unlocking the doors doesn't release; I have to access the touchscreen to "open the charging port", which once again unlocks the adapter.
The most worrisome thing is that simply disconnecting the J1772 causes the car to unlock the charging port (and adapter), even when you walk up to a locked car without the key fob. Be careful at public charging stations--I'm sure the J1772 adapter isn't cheap.
There's a new version of the J1772 adapter that's not has hard to remove. Ask your service manager about it.
Ben,
When you took your charging video was that before the software upgrade to version 4.0?
In your video the J1772 adapter couldn't be removed by without unlocking the car. According to tezco that is no longer the case.
Thanks.
Larry
