Model S 2017 with free unlimited supercharging SC05. The car cannot be charged using a supercharger.
SYMPTOMS
SYMPTOMS
- Plug in (supercharger) charger into the car
- Solid white light in the car charging port
- This means to plug out
- Plug out charger from car
- Immediately plug back in
- Solid white light again
- Plug out charger
- Plug back all the way in but with a little more strenght
- Solid blue light
- Not sure what this means, but it is not charging (blinking blue light)
- Inside the car it shows "Ready to charge" but I don't think there is another button for me to click to "start" charging
- Basically alternating with those 2 scenarios
- If I plug the charger hard all the way in, it shows solid blue light
- If I plug the charger "normally," it shows solid white light
- A month ago I had a warning indicator to change the low voltage battery
- Used the car for 2-3 weeks with the warning (was able to supercharge without any issues during this time).
- First time the car was unable to supercharge happened around this time
- SYMPTOMS happened
- Moved to another slot in the same parking lot, it worked!
- So I assumed there is an issue with that specific charger
- But another tesla came and charged perfectly like nothing is wrong
- A week~ later, I was unable to supercharge again
- SYMPTOMS happened
- Again, moved to another slot in the same parking lot, sometimes it worked, sometimes it didn't
- Completely moved to another parking lot, it worked
- Another week~ later, I was unable to supercharge again
- SYMPTOMS happened
- Again, moved to another slot in the same parking lot, it didn't work at all
- Completely moved to another parking lot, it didn't work at all
- Called tesla through the app and changed the low voltage battery
- The same day the battery was changed, went to charge the car
- SYMPTOMS happened
- Today, 2 weeks have passed since the battery was changed, it stopped charging again.
- SYMPTOMS happened
- Tried 3 different parking lots, several different charging slots, NOTHING
- Only charging at home works right now.
