Luis Mengual
Dear all, let me expose my humble opinion about this amazing thread; giving as base, this car is 4.600lbs 46/54 weight distribuition. (Heavy and powerful rear axis Vs narrow 245 sport tyres is a fact, despite 265 of + series)
-In acceleration stages, this weight change even more to rear axis, burning exponentially as press the right pedal by friction, hysteresis and drift of tyres onto the asphalt.
-Decelerating this weight change forward but assuming that only is retaining rear wheels most of the time, wear tyres by the same principle as accelerating. Stressing 80% rear axis vs 20% front axis only by accelerations/decelerations.
-Incorrect/flexible toe (which is most of Model S), incorrect tyre pressure and sport ride style will increase this degradation suddenly.
Things that can be done to improve this issue:
-When I wear sport tyres, I warm up them by low power delivering and gentle turnings before sport riding.
-Monitoring pressures every 1k or 2 weeks, and inflate with nitrogen (will help to maintaing this pressures)
-Suggest to service, inspect and modify Toe clearance as tight as possible. Notice that when you have more than 2º rear camber you must compensate with slight toe, but if this toe is out aligned or too much mechanical clearances when accel/decel, forget long life.
Conclusion,
Style of riding and proper care and maintenance will help to prolongate tyres life... Sorry for this brick,
Conclusion,
